REST API reference
Deletes a unix user configuration for the specified svm
DELETE /name-services/unix-users/{svm.uuid}/{name}
Introduced In: 9.9
Deletes a UNIX user configuration for the specified SVM.
  • vserver services name-service unix-user delete
name
string
path
True
UNIX user name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
