REST API reference
Delete a specific FPolicy event configuration for an SVM
Deletes a specific FPolicy event configuration for an SVM. This is useful when you need to manage or remove configurations that are no longer required for your storage environment.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/events/{name}
Introduced in
ONTAP 9.6
Usage notes
A cluster-level FPolicy event configuration cannot be modified for a data SVM through REST. An FPolicy event that is attached to an FPolicy policy cannot be deleted.
  • fpolicy policy event delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
Error Code Description
9764874
The FPolicy event is a cluster event
9764947
The FPolicy event is attached to an FPolicy policy
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
