Delete a specific FPolicy event configuration for an SVM
DELETE /protocols/fpolicy/{svm.uuid}/events/{name}
Introduced In: 9.6
Deletes a specific FPolicy event configuration for an SVM. A cluster-level FPolicy event configuration cannot be modified for a data SVM through REST. An FPolicy event that is attached to an FPolicy policy cannot be deleted.
Related ONTAP commands
fpolicy policy event delete
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
| Error Code | Description |
9764874 |
The FPolicy event is a cluster event |
9764947 |
The FPolicy event is attached to an FPolicy policy |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
