REST API reference
Delete an FPolicy configuration for an SVM
Deletes an FPolicy configuration for a specific SVM when you need to remove policies that are no longer required. Ensure the policy is disabled prior to deletion.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes a particular FPolicy policy configuration for a specified SVM. To delete a policy, you must first disable the policy.
  • fpolicy policy scope delete
  • fpolicy policy delete
name
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9764900
Deletion of a cluster level FPolicy policy is not supported
9764941
Cannot delete an enabled FPolicy policy
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
