Delete an FPolicy configuration for an SVM
Removes an FPolicy configuration from an SVM when it is no longer needed or after disabling it. This action helps you manage and streamline policy configurations within your storage virtual machine.
HTTP method and endpoint
DELETE /protocols/fpolicy/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes a particular FPolicy policy configuration for a specified SVM. To delete a policy, you must first disable the policy.
Related ONTAP commands
fpolicy policy scope delete -
fpolicy policy delete
Learn more
name |
string |
path |
True |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764900 |
Deletion of a cluster level FPolicy policy is not supported |
9764941 |
Cannot delete an enabled FPolicy policy |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
