Delete an export policy
Deletes an export policy to remove unwanted or obsolete access configurations for network file systems.
HTTP method and endpoint
DELETE /protocols/nfs/export-policies/{id}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy delete
Learn more
id |
integer |
path |
True |
Export Policy ID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703944 |
Failed to delete rule |
1703945 |
Ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703946 |
Cannot determine if the ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703947 |
Cannot delete default ruleset. This ruleset will be deleted when the owning Vserver is deleted |
1703952 |
Invalid ruleset name provided. No spaces are allowed in a ruleset name |
1703953 |
This ruleset is in use by a qtree export policy. It cannot be deleted until all qtree policies that refer to it are first deleted |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
