Delete an export policy
Deletes an export policy when you want to remove access control settings for exported file systems. Use this to clean up outdated or unnecessary policies.
HTTP method and endpoint
DELETE /protocols/nfs/export-policies/{id}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy delete
Learn more
id |
integer |
path |
True |
Export Policy ID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703944 |
Failed to delete rule |
1703945 |
Ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703946 |
Cannot determine if the ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted |
1703947 |
Cannot delete default ruleset. This ruleset will be deleted when the owning Vserver is deleted |
1703952 |
Invalid ruleset name provided. No spaces are allowed in a ruleset name |
1703953 |
This ruleset is in use by a qtree export policy. It cannot be deleted until all qtree policies that refer to it are first deleted |
1704047 |
The export policy name cannot be longer than 256 characters |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
