REST API reference
Delete an export policy
DELETE /protocols/nfs/export-policies/{id}
Introduced In: 9.6
Deletes an export policy.
  • vserver export-policy delete
id
integer
path
True
Export Policy ID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1703944
Failed to delete rule
1703945
Ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted
1703946
Cannot determine if the ruleset is in use by a volume. It cannot be deleted until all volumes that refer to it are first deleted
1703947
Cannot delete default ruleset. This ruleset will be deleted when the owning Vserver is deleted
1703952
Invalid ruleset name provided. No spaces are allowed in a ruleset name
1703953
This ruleset is in use by a qtree export policy. It cannot be deleted until all qtree policies that refer to it are first deleted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
