ONTAP automation
ONTAP automation options
Contributors dmp-netapp netapp-aoife netapp-revathid
There are several options available to automate the deployment and administration of your ONTAP storage systems.
ONTAP REST API
Beginning with ONTAP 9.6, ONTAP includes a robust REST API that provides the foundation for automating the deployment and administration of your storage systems. Since then the REST API has continued to expand and mature. It now provides the preferred and strategic option when automating the administration of your ONTAP deployments.
Accessing the REST API natively
You can access the ONTAP REST API directly using any programming language that supports a REST client. Popular language choices include Python, PowerShell, and Java.
Migrating legacy ONTAPI code to use REST
The ONTAPI API (Zephyr API or ZAPI) is the original set of proprietary calls included with the NetApp ONTAP software to support the automation of your data storage administration and management tasks. The API is part of the NetApp Manageability SDK. If you have existing code using the ONTAPI API, you should plan your migration to the ONTAP REST API to take advantage of the expanded feature set available with the REST API. NetApp provides support for converting your code to use the newer ONTAP REST API. See Migrate from ONTAPI to the REST API for more information.
Client software toolkits
NetApp provides client toolkits that abstract the ONTAP REST API and make it easier to create automation code. You should choose one appropriate for your development language and environment.
Python client library
The Python client library is a package you can use when writing scripts to access the ONTAP REST API. It provides support for several underlying services, including connection management, asynchronous request processing, and exception handling. By using the Python client library, you can quickly develop robust code to support your ONTAP automation goals. See Python client library for more information.
PowerShell toolkit
You can use the NetApp.ONTAP PowerShell Toolkit to automate the administration of an ONTAP cluster from a Windows host. See Learn about the NetApp ONTAP PowerShell Toolkit for more information.
Automation frameworks
You can create and deploy automation code using one of several frameworks.
Ansible
Ansible is an open-source software tool that supports provisioning, configuration management, and application deployment. Since its release and subsequent acquisition by RedHat, it has continued to grow in popularity. NetApp provides Ansible-certified modules that customers can use to automate the administration of their ONTAP storage systems. See Learn more and NetApp Ansible DevOps Solutions for additional information.
NetApp Console automation hub
The NetApp Console automation hub is available through the Console web user interface. The automation hub provides access to packaged solutions that can help you to automate the deployment and integration of ONTAP with other products. See NetApp automation for documentation and more information.
