Manage NFS export policies
Manage NFS export policies to control access to exported file systems in your ONTAP environment. Use these endpoints to create, update, retrieve, and delete export policies and their associated rules and clients.
Export Policies
1) Retrieve the export policy details
# The API: GET /api/protocols/nfs/export-policies # The call: curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies"
2) Create an export policy for an SVM
# The API:
POST /api/protocols/nfs/export-policies
# The call:
curl -d "@test_post_policy_single_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies"
test_post_policy_single_rule.txt(body):
"name": "P1",
"rules":[
"clients": [
"match": "host1"
"ro_rule": [
"krb5"
"rw_rule": [
"ntlm"
"anonymous_user": "anon1",
"chown_mode": "restricted",
"allow_suid": true
"clients": [
"match": "host2"
"ro_rule": [
"sys"
"rw_rule": [
"ntlm"
"superuser": [
"any"
"allow_device_creation": true,
"ntfs_unix_security": "fail"
3) Update an export policy for an SVM
# The API:
PATCH /api/protocols/nfs/export-policies/{policy.id}
# The call:
curl -d "@test_patch_policy.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594"
test_patch_policy.txt(body):
"name": "S1",
"rules":[
"clients": [
"match": "host4"
"ro_rule": [
"krb5"
"rw_rule": [
"ntlm"
4) Delete an export policy for an SVM
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594"
Export Rules
1) Retrieve the export policy rule details for an export policy
# The API:
GET /api/protocols/nfs/export-policies/{policy.id}/rules
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules"
2) Create an export policy rule for an export policy
# The API:
POST /api/protocols/nfs/export-policies/{policy.id}/rules
# The call:
curl -d "@test_patch_export_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules"
test_patch_export_rule.txt(body):
"clients": [
"match": "host2"
"ro_rule": [
"sys"
"rw_rule": [
"ntlm"
3) Update an export policy rule for an export policy
# The API:
PATCH /api/protocols/nfs/export-policies/{policy.id}/rules/{index}
# The call:
curl -d "@test_patch_export_rule.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/5?new_index=10"
"clients": [
"match": "host4"
"ro_rule": [
"sys"
"rw_rule": [
"krb5"
4) Delete an export policy rule for an export policy
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/15"
Export Clients
1) Retrieve the export client matches of an export policy rule
# The API:
GET /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/2/clients"
2) Add an export client match to an export policy rule
# The API:
POST /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
# The call:
curl -d "@add_client_match.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients"
add_client_match.txt(body):
"match" : "host4"
3) Delete an export client match from an export policy rule
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients/host1,host2"
