REST API reference
Manage NFS export policies
Export Policies
1) Retrieve the export policy details
# The API:
GET /api/protocols/nfs/export-policies
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies"
2) Create an export policy for an SVM
# The API:
POST /api/protocols/nfs/export-policies
# The call:
curl -d "@test_post_policy_single_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies"
test_post_policy_single_rule.txt(body):
"name": "P1",
"rules":[
    "clients": [
        "match": "host1"
    "ro_rule": [
      "krb5"
    "rw_rule": [
      "ntlm"
    "anonymous_user": "anon1",
    "chown_mode": "restricted",
    "allow_suid": true
    "clients": [
        "match": "host2"
    "ro_rule": [
      "sys"
    "rw_rule": [
      "ntlm"
    "superuser": [
      "any"
    "allow_device_creation": true,
    "ntfs_unix_security": "fail"
3) Update an export policy for an SVM
# The API:
PATCH /api/protocols/nfs/export-policies/{policy.id}
# The call:
curl -d "@test_patch_policy.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594"
test_patch_policy.txt(body):
"name": "S1",
"rules":[
    "clients": [
        "match": "host4"
    "ro_rule": [
      "krb5"
    "rw_rule": [
      "ntlm"
4) Delete an export policy for an SVM
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934594"
Export Rules
1) Retrieve the export policy rule details for an export policy
# The API:
GET /api/protocols/nfs/export-policies/{policy.id}/rules
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules"
2) Create an export policy rule for an export policy
# The API:
POST /api/protocols/nfs/export-policies/{policy.id}/rules
# The call:
curl -d "@test_patch_export_rule.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules"
test_patch_export_rule.txt(body):
"clients": [
    "match": "host2"
"ro_rule": [
  "sys"
"rw_rule": [
  "ntlm"
3) Update an export policy rule for an export policy
# The API:
PATCH /api/protocols/nfs/export-policies/{policy.id}/rules/{index}
# The call:
curl -d "@test_patch_export_rule.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/5?new_index=10"
"clients": [
    "match": "host4"
"ro_rule": [
  "sys"
"rw_rule": [
  "krb5"
4) Delete an export policy rule for an export policy
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934595/rules/15"
Export Clients
1) Retrieve the export client matches of an export policy rule
# The API:
GET /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/2/clients"
2) Add an export client match to an export policy rule
# The API:
POST /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
# The call:
curl -d "@add_client_match.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients"
add_client_match.txt(body):
"match" : "host4"
3) Delete an export client match from an export policy rule
# The API:
DELETE /api/protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/export-policies/8589934593/rules/1/clients/host1,host2"
