REST API reference
Delete an NVMe service
Deletes an NVMe service when you no longer need it and have disabled the service. This operation helps you manage the configuration of NVMe resources associated with the storage virtual machine (SVM).
HTTP method and endpoint
DELETE /protocols/nvme/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An NVMe service must be disabled before it can be deleted. In addition, all NVMe interfaces, subsystems, and subsystem maps associated with the SVM must first be deleted.
  • vserver nvme delete
svm.uuid
string
path
True
The unique identifier of the SVM whose NVMe service is to be deleted.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
The supplied SVM does not exist.
72089651
The supplied SVM does not have an NVMe service.
72089653
There are subsystems associated with the NVMe service SVM. The subsystems must be removed before deleting the NVMe service.
72089654
There are NVMe-oF LIFs associated with the NVMe service SVM. The LIFs must be removed before deleting the NVMe service.
72090028
The NVMe service is enabled. The NVMe service must be disabled before it can be deleted.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
