Delete an NVMe service
Deletes an NVMe service when you need to remove it from your configuration, ensuring all related components are cleared beforehand.
HTTP method and endpoint
DELETE /protocols/nvme/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An NVMe service must be disabled before it can be deleted. In addition, all NVMe interfaces, subsystems, and subsystem maps associated with the SVM must first be deleted.
Related ONTAP commands
vserver nvme delete
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM whose NVMe service is to be deleted. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The supplied SVM does not exist. |
72089651 |
The supplied SVM does not have an NVMe service. |
72089653 |
There are subsystems associated with the NVMe service SVM. The subsystems must be removed before deleting the NVMe service. |
72089654 |
There are NVMe-oF LIFs associated with the NVMe service SVM. The LIFs must be removed before deleting the NVMe service. |
72090028 |
The NVMe service is enabled. The NVMe service must be disabled before it can be deleted. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
