Delete an S3 bucket configuration for an SVM
Deletes the S3 bucket configuration associated with an SVM. This action also removes the access policy tied to the bucket.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the S3 bucket configuration of an SVM. An access policy is also deleted on an S3 bucket "delete" command.
Related ONTAP commands
vserver object-store-server bucket delete -
vserver object-store-server bucket policy statement delete -
vserver object-store-server bucket policy-statement-condition delete
uuid |
string |
path |
True |
The unique identifier of the bucket. |
return_timeout |
integer |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error code | Message |
92405811 |
"Failed to delete bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again."; |
92405858 |
"Failed to "delete" the "bucket" because the operation is only supported on data SVMs."; |
92405861 |
"The specified SVM UUID or bucket UUID does not exist."; |
92405779 |
"Failed to remove bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. "; |
92405813 |
"Failed to delete the object store volume. Reason: {Reason for failure}."; |
92405864 |
"An error occurred when deleting an access policy. The reason for failure is detailed in the error message."; |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
