REST API reference
Delete an S3 bucket configuration for an SVM
Deletes the S3 bucket configuration for an SVM, effectively removing its associated access policy and all CORS rules.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Deletes the S3 bucket configuration of an SVM. An access policy is also deleted on an S3 bucket "delete" command. All CORS rules are also deleted on bucket deletion.
  • vserver object-store-server bucket delete
  • vserver object-store-server bucket policy statement delete
  • vserver object-store-server bucket policy-statement-condition delete
  • vserver object-store-server bucket lifecycle-management-rule delete
  • vserver object-store-server bucket cors-rule delete
uuid
string
path
True
The unique identifier of the bucket.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error code Message
92405811
"Failed to delete bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again.";
92405858
"Failed to "delete" the "bucket" because the operation is only supported on data SVMs.";
92405861
"The specified SVM UUID or bucket UUID does not exist.";
92405779
"Failed to remove bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. ";
92405813
"Failed to delete the object store volume. Reason: {Reason for failure}.";
92405864
"An error occurred when deleting an access policy. The reason for failure is detailed in the error message.";
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
