Delete an S3 bucket configuration for an SVM
DELETE /protocols/s3/services/{svm.uuid}/buckets/{uuid}
Deletes the S3 bucket configuration of an SVM.
Related ONTAP commands
vserver object-store-server bucket delete
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
uuid |
string |
path |
True |
The unique identifier of the bucket. |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error code | Message |
92405811 |
"Failed to delete bucket "{bucket name}" for SVM "{svm.name}". Wait a few minutes and try the operation again."; |
92405858 |
"Failed to "delete" the "bucket" because the operation is only supported on data SVMs."; |
92405861 |
"The specified SVM UUID or bucket UUID does not exist."; |
92405779 |
"Failed to remove bucket "{bucket name}" for SVM "{svm.name}". Reason: {Reason for failure}. "; |
92405813 |
"Failed to delete the object store volume. Reason: {Reason for failure}."; |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
