REST API reference
Delete the S3 group configuration for an SVM
Deletes the S3 group configuration for an SVM, removing it from the storage virtual machine's object store settings.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Deletes the S3 group configuration of an SVM.
  • vserver object-store-server group delete
id
string
path
True
Group identifier that identifies the unique group.
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
