Delete an S3 group configuration for an SVM
Deletes the S3 group configuration for an SVM, removing it from the storage virtual machine's object store settings.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Deletes the S3 group configuration of an SVM.
Related ONTAP commands
vserver object-store-server group delete
Learn more
id |
string |
path |
True |
Group identifier that identifies the unique group. |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
