REST API reference
Delete an iSCSI service
Deletes an iSCSI service when it is no longer needed for SAN protocols, ensuring that resources are managed effectively within your storage environment.
HTTP method and endpoint
DELETE /protocols/san/iscsi/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
An iSCSI service must be disabled before it can be deleted.
  • vserver iscsi delete
svm.uuid
string
path
True
The unique identifier of the SVM for which to delete the iSCSI service.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
5373960
The iSCSI service is enabled. The iSCSI service must be disabled before it can be deleted.
5374078
The SVM does not have an iSCSI service.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
