Delete an iSCSI service
Removes an iSCSI service when it is no longer needed or has been disabled. This action helps maintain the efficiency and security of your storage environment.
HTTP method and endpoint
DELETE /protocols/san/iscsi/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes an iSCSI service. An iSCSI service must be disabled before it can be deleted.
Related ONTAP commands
vserver iscsi delete
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM for which to delete the iSCSI service. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
5373960 |
The iSCSI service is enabled. The iSCSI service must be disabled before it can be deleted. |
5374078 |
The SVM does not have an iSCSI service. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
