REST API reference
Delete a LUN map
Deletes a LUN map to remove the association between a logical unit number and an initiator group, freeing the LUN from access by the specified initiators.
HTTP method and endpoint
DELETE /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced in
ONTAP 9.6
  • lun mapping delete
lun.uuid
string
path
True
igroup.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN does not exist or is not accessible to the caller.
5374878
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN.
5374922
The specified LUN map does not exist.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
