Delete a LUN map
Deletes a logical unit number (LUN) map to remove the association between a LUN and its initiator group. This operation is useful when you need to change access configurations or decommission storage mappings.
HTTP method and endpoint
DELETE /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes a LUN map.
Related ONTAP commands
lun mapping delete
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
local_delete_only |
boolean |
query |
False |
Delete the local map and set the
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374922 |
The specified LUN map does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
