REST API reference
Delete a user account
Deletes a user account, removing access for the specified account name within the given SVM. Use this endpoint when you need to manage user access by removing inactive or unauthorized accounts.
HTTP method and endpoint
DELETE /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Required parameters
  • name - Account name to be deleted.
  • owner.uuid - UUID of the SVM housing the user account to be deleted.
  • security login delete
owner.uuid
string
path
True
Account owner UUID
name
string
path
True
User account name
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5636098
Last unlocked account that has an admin role cannot be deleted.
5636125
The operation is not supported on system accounts.
5636146
Cannot delete the last console account with admin role.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
