Delete a user account
Deletes a user account to remove access and credentials associated with that account from the system. Use this operation when you need to manage user access or clean up obsolete accounts.
HTTP method and endpoint
DELETE /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Required parameters
name- Account name to be deleted. -
owner.uuid- UUID of the SVM housing the user account to be deleted.
Related ONTAP commands
security login delete
owner.uuid |
string |
path |
True |
Account owner UUID |
name |
string |
path |
True |
User account name |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636098 |
Last unlocked account that has an admin role cannot be deleted. |
5636125 |
The operation is not supported on system accounts. |
5636146 |
Cannot delete the last console account with admin role. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
