REST API reference
Delete a Google Cloud KMS configuration
Removes a Google Cloud KMS configuration, ensuring that the specified configuration is no longer active within your environment.
HTTP method and endpoint
DELETE /security/gcp-kms/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Deletes a Google Cloud KMS configuration.
  • security key-manager external gcp disable
uuid
string
path
True
Google Cloud KMS UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536242
One or more self-encrypting drives are assigned an authentication key.
65536243
Cannot determine authentication key presence on one or more self-encrypting drives.
65536817
Internal error. Failed to determine if it is safe to disable key manager.
65536827
Internal error. Failed to determine if the given SVM has any encrypted volumes.
65536834
Internal error. Failed to get existing key-server details for the given SVM.
65536867
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM.
65536883
Internal error. Volume encryption key is missing for a volume.
65536884
Internal error. Volume encryption key is invalid for a volume.
65536924
Cannot remove key manager that still contains one or more authentication keys for self-encrypting drives.
65537721
The Google Cloud Key Management Service is not configured for the SVM.
196608080
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption).
196608301
Internal error. Failed to get encryption type.
196608305
NAE aggregates found in the cluster.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
