Delete a Google Cloud KMS configuration
Removes a Google Cloud KMS configuration when you no longer need it for managing encryption keys in your ONTAP system.
HTTP method and endpoint
DELETE /security/gcp-kms/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Deletes a Google Cloud KMS configuration.
Related ONTAP commands
security key-manager external gcp disable
uuid |
string |
path |
True |
Google Cloud KMS UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536817 |
Internal error. Failed to determine if it is safe to disable key manager. |
65536827 |
Internal error. Failed to determine if the given SVM has any encrypted volumes. |
65536834 |
Internal error. Failed to get existing key-server details for the given SVM. |
65536867 |
Volume encryption keys (VEK) for one or more encrypted volumes are stored on the key manager configured for the given SVM. |
65536883 |
Internal error. Volume encryption key is missing for a volume. |
65536884 |
Internal error. Volume encryption key is invalid for a volume. |
65537721 |
The Google Cloud Key Management Service is not configured for the SVM. |
196608080 |
One or more nodes in the cluster have the root volume encrypted using NVE (NetApp Volume Encryption). |
196608301 |
Internal error. Failed to get encryption type. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
