REST API reference
Delete key managers
Deletes a key manager to manage your security configurations and remove unused or outdated key management entries.
HTTP method and endpoint
DELETE /security/key-managers/{uuid}
Introduced in
ONTAP 9.6
  • security key-manager external disable
  • security key-manager onboard disable
uuid
string
path
True
Key manager UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536208
Failed to delete the SVM Key ID.
65536233
Internal error. Deletion of km_wrapped_kdb key database has failed for the Onboard Key Manager.
65536234
Internal error. Deletion of cluster_kdb key database has failed for the Onboard Key Manager.
65536239
Encrypted volumes are found for the SVM.
65536242
One or more self-encrypting drives are assigned an authentication key.
65536243
Cannot determine authentication key presence on one or more self-encrypting drives.
65536800
Failed to lookup onboard keys.
65536813
Encrypted kernel core files found.
65536817
Failed to determine if key manager is safe to disable.
65536822
Multitenant key management is not supported in the current cluster version.
65536827
Failed to determine if the SVM has any encrypted volumes.
65536828
External key management is not enabled for the SVM.
65536867
196608301
Failed to determine the type of encryption.
196608305
NAE aggregates are found in the cluster.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
