Delete key managers
Deletes a key manager to remove its configuration and association from the system. This action is typically performed when a key manager is no longer needed or requires replacement.
HTTP method and endpoint
DELETE /security/key-managers/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
security key-manager external disable -
security key-manager onboard disable
uuid |
string |
path |
True |
Key manager UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536208 |
Failed to delete the SVM Key ID. |
65536233 |
Internal error. Deletion of km_wrapped_kdb key database has failed for the Onboard Key Manager. |
65536234 |
Internal error. Deletion of cluster_kdb key database has failed for the Onboard Key Manager. |
65536239 |
Encrypted volumes are found for the SVM. |
65536242 |
One or more self-encrypting drives are assigned an authentication key. |
65536243 |
Cannot determine authentication key presence on one or more self-encrypting drives. |
65536800 |
Failed to lookup onboard keys. |
65536813 |
Encrypted kernel core files found. |
65536817 |
Failed to determine if key manager is safe to disable. |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536827 |
Failed to determine if the SVM has any encrypted volumes. |
65536828 |
External key management is not enabled for the SVM. |
65536867 |
65536977 |
Failed to disable the key manager because of a timeout when checking for encrypted cores. |
196608301 |
Failed to determine the type of encryption. |
196608305 |
NAE aggregates are found in the cluster. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
