REST API reference
Delete an aggregate specified by the UUID
Deletes a specified ONTAP aggregate, initiating a job that handles the removal process. Use this operation when you need to manage storage resources by removing aggregates that are no longer required.
HTTP method and endpoint
DELETE /storage/aggregates/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the aggregate specified by the UUID. This request starts a job and returns a link to that job.
  • storage aggregate delete
uuid
string
path
True
Aggregate UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
460770
The aggregate delete job failed to delete the aggregate.
460777
Failed to get information on the delete job.
786435
Internal Error. Failed to create a communication handle.
786451
Failed to delete specified aggregate.
786468
VLDB is offline.
786472
Node that hosts the aggregate is offline.
786497
Cannot delete an aggregate that has volumes.
786771
Aggregate does not exist.
786867
Specified aggregate resides on the remote cluster.
786897
Specified aggregate cannot be deleted as it is a switched-over root aggregate.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
