Delete an aggregate specified by the UUID
Removes an aggregate identified by its UUID, initiating a job that manages the deletion process. Use this operation when you need to decommission storage resources.
HTTP method and endpoint
DELETE /storage/aggregates/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the aggregate specified by the UUID. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate delete
uuid |
string |
path |
True |
Aggregate UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
460770 |
The aggregate delete job failed to delete the aggregate. |
460777 |
Failed to get information on the delete job. |
786435 |
Internal Error. Failed to create a communication handle. |
786451 |
Failed to delete specified aggregate. |
786468 |
VLDB is offline. |
786472 |
Node that hosts the aggregate is offline. |
786497 |
Cannot delete an aggregate that has volumes. |
786771 |
Aggregate does not exist. |
786867 |
Specified aggregate resides on the remote cluster. |
786897 |
Specified aggregate cannot be deleted as it is a switched-over root aggregate. |
19726544 |
DELETE on the aggregate endpoint is not supported on this version of ONTAP. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
