REST API reference
Cancel a fingerprint operation
Cancels an ongoing fingerprint operation associated with a specific session ID, stopping the process before completion.
HTTP method and endpoint
DELETE /storage/snaplock/file-fingerprints/{id}
Introduced in
ONTAP 9.7
Usage notes
Aborts an in-progress fingerprint operation. This API takes session-id as input and aborts the fingerprint operation that is associated with the specified session-id.
  • volume file fingerprint abort
id
string
path
True
Unique identifier of the operation
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090440
File fingerprint operation has completed
14090446
Invalid session ID
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
