Cancel a fingerprint operation
DELETE /storage/snaplock/file-fingerprints/{id}
Introduced In: 9.7
Aborts an in-progress fingerprint operation. This API takes session-id as input and aborts the fingerprint operation that is associated with the specified session-id.
Related ONTAP commands
volume file fingerprint abort
Learn more
id |
string |
path |
True |
Unique identifier of the operation |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090440 |
File fingerprint operation has completed |
14090446 |
Invalid session ID |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
