REST API reference
Delete a schedule from a Snapshot copy policy
Removes a schedule from a Snapshot copy policy to modify the policy's timing or frequency. Use this when you need to adjust or discontinue specific snapshot creation schedules.
HTTP method and endpoint
DELETE /storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes a schedule from a Snapshot copy policy
  • snapshot policy remove-schedule
string
path
True
Snapshot copy policy UUID
schedule.uuid
string
path
True
Snapshot copy policy schedule UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638412
Schedule does not exist in Snapshot policy.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
