REST API reference
Delete a schedule from a Snapshot copy policy
Deletes a schedule from a Snapshot copy policy, removing the specified timing and frequency for creating Snapshot copies. Use this operation when you need to adjust or discontinue the automated Snapshot creation schedule.
HTTP method and endpoint
DELETE /storage/snapshot-policies/{snapshot_policy.uuid}/schedules/{schedule.uuid}
Introduced in
ONTAP 9.8
Usage notes
  • snapshot policy remove-schedule
string
path
True
Snapshot copy policy UUID
schedule.uuid
string
path
True
Snapshot copy policy schedule UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638411
At least minimum number of schedule must be specified for the policy.
1638412
Schedule does not exist in Snapshot policy.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
