REST API reference
Retrieve a consistency group
Retrieves a single consistency group to access its detailed configuration and properties. Use this when you need specific information about a group, including its associated volumes, LUNs, or namespaces.
HTTP method and endpoint
GET /application/consistency-groups/{uuid}
Introduced in
ONTAP 9.10
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • volumes
  • luns
  • namespaces
There are no ONTAP commands for managing consistency groups.
uuid
string
path
True
The unique identifier of the group to retrieve.
luns.space.size
integer
query
False
Filter by luns.space.size
luns.space.used
integer
query
False
Filter by luns.space.used
luns.enabled
boolean
query
False
Filter by luns.enabled
luns.name
string
query
False
Filter by luns.name
luns.lun_maps.logical_unit_number
integer
query
False
Filter by luns.lun_maps.logical_unit_number
luns.lun_maps.igroup.uuid
string
query
False
Filter by luns.lun_maps.igroup.uuid
luns.lun_maps.igroup.os_type
string
query
False
Filter by luns.lun_maps.igroup.os_type
luns.lun_maps.igroup.igroups.uuid
string
query
False
Filter by luns.lun_maps.igroup.igroups.uuid
luns.lun_maps.igroup.igroups.name
string
query
False
Filter by luns.lun_maps.igroup.igroups.name
luns.lun_maps.igroup.name
string
query
False
Filter by luns.lun_maps.igroup.name
luns.lun_maps.igroup.protocol
string
query
False
Filter by luns.lun_maps.igroup.protocol
luns.lun_maps.igroup.initiators.comment
string
query
False
Filter by luns.lun_maps.igroup.initiators.comment
luns.lun_maps.igroup.initiators.name
string
query
False
Filter by luns.lun_maps.igroup.initiators.name
luns.create_time
string
query
False
Filter by luns.create_time
luns.os_type
string
query
False
Filter by luns.os_type
luns.qos.policy.uuid
string
query
False
Filter by luns.qos.policy.uuid
luns.qos.policy.min_throughput_iops
integer
query
False
Filter by luns.qos.policy.min_throughput_iops
luns.qos.policy.max_throughput_iops
integer
query
False
Filter by luns.qos.policy.max_throughput_iops
luns.qos.policy.min_throughput_mbps
integer
query
False
Filter by luns.qos.policy.min_throughput_mbps
luns.qos.policy.name
string
query
False
Filter by luns.qos.policy.name
luns.qos.policy.max_throughput_mbps
integer
query
False
Filter by luns.qos.policy.max_throughput_mbps
luns.uuid
string
query
False
Filter by luns.uuid
luns.serial_number
string
query
False
Filter by luns.serial_number
luns.comment
string
query
False
Filter by luns.comment
replicated
boolean
query
False
Filter by replicated
integer
query
False
Filter by qos.policy.min_throughput_mbps
qos.policy.name
string
query
False
Filter by qos.policy.name
integer
query
False
Filter by qos.policy.max_throughput_mbps
qos.policy.uuid
string
query
False
Filter by qos.policy.uuid
integer
query
False
Filter by qos.policy.min_throughput_iops
integer
query
False
Filter by qos.policy.max_throughput_iops
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
space.used
integer
query
False
Filter by space.used
space.available
integer
query
False
Filter by space.available
space.size
integer
query
False
Filter by space.size
tiering.policy
string
query
False
Filter by tiering.policy
parent_consistency_group.uuid
string
query
False
Filter by parent_consistency_group.uuid
parent_consistency_group.name
string
query
False
Filter by parent_consistency_group.name
snapshot_policy.uuid
string
query
False
Filter by snapshot_policy.uuid
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
name
string
query
False
Filter by name
consistency_groups.qos.policy.min_throughput_mbps
integer
query
False
Filter by consistency_groups.qos.policy.min_throughput_mbps
consistency_groups.qos.policy.name
string
query
False
Filter by consistency_groups.qos.policy.name
consistency_groups.qos.policy.max_throughput_mbps
integer
query
False
Filter by consistency_groups.qos.policy.max_throughput_mbps
consistency_groups.qos.policy.uuid
string
query
False
Filter by consistency_groups.qos.policy.uuid
consistency_groups.qos.policy.min_throughput_iops
integer
query
False
Filter by consistency_groups.qos.policy.min_throughput_iops
consistency_groups.qos.policy.max_throughput_iops
integer
query
False
Filter by consistency_groups.qos.policy.max_throughput_iops
consistency_groups.uuid
string
query
False
Filter by consistency_groups.uuid
consistency_groups.parent_consistency_group.uuid
string
query
False
Filter by consistency_groups.parent_consistency_group.uuid
consistency_groups.parent_consistency_group.name
string
query
False
Filter by consistency_groups.parent_consistency_group.name
consistency_groups.snapshot_policy.uuid
string
query
False
Filter by consistency_groups.snapshot_policy.uuid
consistency_groups.snapshot_policy.name
string
query
False
Filter by consistency_groups.snapshot_policy.name
consistency_groups.luns.space.size
integer
query
False
Filter by consistency_groups.luns.space.size
consistency_groups.luns.space.used
integer
query
False
Filter by consistency_groups.luns.space.used
consistency_groups.luns.enabled
boolean
query
False
Filter by consistency_groups.luns.enabled
consistency_groups.luns.name
string
query
False
Filter by consistency_groups.luns.name
consistency_groups.luns.lun_maps.logical_unit_number
integer
query
False
Filter by consistency_groups.luns.lun_maps.logical_unit_number
consistency_groups.luns.lun_maps.igroup.uuid
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.uuid
consistency_groups.luns.lun_maps.igroup.os_type
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.os_type
consistency_groups.luns.lun_maps.igroup.igroups.uuid
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.igroups.uuid
consistency_groups.luns.lun_maps.igroup.igroups.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.igroups.name
consistency_groups.luns.lun_maps.igroup.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.name
consistency_groups.luns.lun_maps.igroup.protocol
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.protocol
consistency_groups.luns.lun_maps.igroup.initiators.comment
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.initiators.comment
consistency_groups.luns.lun_maps.igroup.initiators.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.initiators.name
consistency_groups.luns.create_time
string
query
False
Filter by consistency_groups.luns.create_time
consistency_groups.luns.os_type
string
query
False
Filter by consistency_groups.luns.os_type
consistency_groups.luns.qos.policy.uuid
string
query
False
Filter by consistency_groups.luns.qos.policy.uuid
consistency_groups.luns.qos.policy.min_throughput_iops
integer
query
False
Filter by consistency_groups.luns.qos.policy.min_throughput_iops
consistency_groups.luns.qos.policy.max_throughput_iops
integer
query
False
Filter by consistency_groups.luns.qos.policy.max_throughput_iops
consistency_groups.luns.qos.policy.min_throughput_mbps
integer
query
False
Filter by consistency_groups.luns.qos.policy.min_throughput_mbps
consistency_groups.luns.qos.policy.name
string
query
False
Filter by consistency_groups.luns.qos.policy.name
consistency_groups.luns.qos.policy.max_throughput_mbps
integer
query
False
Filter by consistency_groups.luns.qos.policy.max_throughput_mbps
consistency_groups.luns.uuid
string
query
False
Filter by consistency_groups.luns.uuid
consistency_groups.luns.serial_number
string
query
False
Filter by consistency_groups.luns.serial_number
consistency_groups.luns.comment
string
query
False
Filter by consistency_groups.luns.comment
consistency_groups.tiering.policy
string
query
False
Filter by consistency_groups.tiering.policy
consistency_groups.volumes.uuid
string
query
False
Filter by consistency_groups.volumes.uuid
consistency_groups.volumes.qos.policy.min_throughput_mbps
integer
query
False
Filter by consistency_groups.volumes.qos.policy.min_throughput_mbps
consistency_groups.volumes.qos.policy.name
string
query
False
Filter by consistency_groups.volumes.qos.policy.name
consistency_groups.volumes.qos.policy.max_throughput_mbps
integer
query
False
Filter by consistency_groups.volumes.qos.policy.max_throughput_mbps
consistency_groups.volumes.qos.policy.uuid
string
query
False
Filter by consistency_groups.volumes.qos.policy.uuid
consistency_groups.volumes.qos.policy.min_throughput_iops
integer
query
False
Filter by consistency_groups.volumes.qos.policy.min_throughput_iops
consistency_groups.volumes.qos.policy.max_throughput_iops
integer
query
False
Filter by consistency_groups.volumes.qos.policy.max_throughput_iops
consistency_groups.volumes.snapshot_policy.uuid
string
query
False
Filter by consistency_groups.volumes.snapshot_policy.uuid
consistency_groups.volumes.snapshot_policy.name
string
query
False
Filter by consistency_groups.volumes.snapshot_policy.name
consistency_groups.volumes.comment
string
query
False
Filter by consistency_groups.volumes.comment
consistency_groups.volumes.tiering.policy
string
query
False
Filter by consistency_groups.volumes.tiering.policy
consistency_groups.volumes.language
string
query
False
Filter by consistency_groups.volumes.language
consistency_groups.volumes.space.size
integer
query
False
Filter by consistency_groups.volumes.space.size
consistency_groups.volumes.space.available
integer
query
False
Filter by consistency_groups.volumes.space.available
consistency_groups.volumes.space.used
integer
query
False
Filter by consistency_groups.volumes.space.used
consistency_groups.volumes.name
string
query
False
Filter by consistency_groups.volumes.name
consistency_groups.space.used
integer
query
False
Filter by consistency_groups.space.used
consistency_groups.space.size
integer
query
False
Filter by consistency_groups.space.size
consistency_groups.space.available
integer
query
False
Filter by consistency_groups.space.available
consistency_groups.name
string
query
False
Filter by consistency_groups.name
consistency_groups.svm.uuid
string
query
False
Filter by consistency_groups.svm.uuid
consistency_groups.svm.name
string
query
False
Filter by consistency_groups.svm.name
volumes.uuid
string
query
False
Filter by volumes.uuid
integer
query
False
Filter by volumes.qos.policy.min_throughput_mbps
string
query
False
Filter by volumes.qos.policy.name
integer
query
False
Filter by volumes.qos.policy.max_throughput_mbps
string
query
False
Filter by volumes.qos.policy.uuid
integer
query
False
Filter by volumes.qos.policy.min_throughput_iops
integer
query
False
Filter by volumes.qos.policy.max_throughput_iops
string
query
False
Filter by volumes.snapshot_policy.uuid
string
query
False
Filter by volumes.snapshot_policy.name
volumes.comment
string
query
False
Filter by volumes.comment
string
query
False
Filter by volumes.tiering.policy
volumes.language
string
query
False
Filter by volumes.language
volumes.space.size
integer
query
False
Filter by volumes.space.size
integer
query
False
Filter by volumes.space.available
volumes.space.used
integer
query
False
Filter by volumes.space.used
volumes.name
string
query
False
Filter by volumes.name
replication_source
boolean
query
False
Filter by replication_source
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
consistency_groups
array[consistency_groups]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A consistency group can only be associated with one direct parent consistency group.
luns
array[luns]
The LUNs array can be used to create or modify LUNs in a consistency group on a new or existing volume that is a member of the consistency group. LUNs are considered members of a consistency group if they are located on a volume that is a member of the consistency group.
name
string
Name of the consistency group. The consistency group name must be unique within an SVM.
If not provided and the consistency group contains only one volume, the name will be generated based on the volume name. If the consistency group contains more than one volume, the name is required.
namespaces
array[namespaces]
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the SVM using the NVMe over Fabrics protocol. In ONTAP, an NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. NVMe namespaces support being cloned. An NVMe namespace cannot be renamed, resized, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace. See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol.
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
  • Introduced in: 9.10
  • x-ntap-modifyOnly: true
The parent consistency group.
provisioning_options
Options that are applied to the operation.
qos
qos
replicated
boolean
Indicates whether or not replication has been enabled on this consistency group.
replication_source
boolean
Indicates whether or not this consistency group is the source for replication.
restore_to
restore_to
Use to restore a consistency group to a previous Snapshot copy
snapshot_policy
snapshot_policy_reference
This is a reference to the Snapshot copy policy.
space
space
Space information for the consistency group.
svm
svm_reference
tiering
tiering
The tiering placement and policy definitions for volumes in this consistency group.
uuid
string
The unique identifier of the consistency group. The UUID is generated by ONTAP when the consistency group is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
volumes
array[volumes]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A volume can only be associated with one direct parent consistency group.
The volumes array can be used to create new volumes in the consistency group, add existing volumes to the consistency group, or modify existing volumes that are already members of the consistency group.
The total number of volumes across all child consistency groups contained in a consistency group is constrained by the same limit.
      "href": "/api/resourcelink"
  "consistency_groups": [
      "luns": [
          "comment": "string",
          "create_time": "2018-06-04T19:00:00Z",
          "lun_maps": [
              "igroup": {
                "igroups": [
                    "name": "igroup1",
                "initiators": [
                    "comment": "my comment",
                    "name": "iqn.1998-01.com.corp.iscsi:name1"
                "name": "igroup1",
                "os_type": "string",
                "protocol": "string",
          "name": "/vol/volume1/lun1",
          "qos": {
            "policy": {
              "max_throughput_iops": 10000,
              "max_throughput_mbps": 500,
              "min_throughput_iops": 2000,
              "min_throughput_mbps": 500,
              "name": "performance",
          "serial_number": "string",
          "space": {
            "size": 1073741824,
            "used": 0
      "name": "string",
      "namespaces": [
          "name": "/vol/volume1/qtree1/namespace1",
          "subsystem_map": [
              "anagrpid": "00103050h",
              "nsid": "00000001h",
              "subsystem": {
                "name": "string",
      "parent_consistency_group": {
        "name": "my_consistency_group",
      "qos": {
        "policy": {
      "restore_to": {
        "snapshot": {
          "name": "string",
          "uuid": "string"
      "snapshot_policy": {
        "name": "default",
      "space": {
        "available": 5737418,
        "size": 1073741824,
        "used": 5737418
      "svm": {
        "name": "svm1",
      "tiering": {
        "policy": "string"
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volumes": [
          "language": "string",
          "name": "vol_cs_dept",
          "qos": {
            "policy": {
            "name": "default",
          "space": {
            "available": 0,
            "used": 0
          "tiering": {
            "policy": "string"
  "luns": [
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
            "name": "igroup1",
      "qos": {
        "policy": {
      "space": {
        "size": 1073741824,
        "used": 0
  "name": "string",
  "namespaces": [
      "subsystem_map": [
          "subsystem": {
            "name": "string",
  "qos": {
    "policy": {
  "restore_to": {
    "snapshot": {
      "name": "string",
      "uuid": "string"
    "name": "default",
  "space": {
    "size": 1073741824,
    "used": 5737418
  "svm": {
    "name": "svm1",
  "tiering": {
    "policy": "string"
  "volumes": [
      "qos": {
        "policy": {
        "name": "default",
      "space": {
        "available": 0,
        "used": 0
      "tiering": {
        "policy": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
igroups
_links
self_link
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
igroups
array[igroups]
Separate igroup definitions to include in this igroup.
initiators
array[initiators]
The initiators that are members of the group.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through the Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • Introduced in: 9.6
  • readCreate: 1
policy
The QoS policy
_links
self_link
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
policy
policy
The QoS policy
space
The storage space related properties of the LUN.
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not reduced using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maxiumum sizes vary depending on the ONTAP version, ONTAP platform, and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Max value: 140737488355328
  • Min value: 4096
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
luns
A LUN is the logical representation of storage in a storage area network (SAN).
In ONTAP, a LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, and moved to a different volume. LUNs support the assignment of a quality of service (QoS) policy for performance management or a QoS policy can be assigned to the volume containing the LUN. See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the Fibre Channel Protocol or a TCP/IP network using iSCSI.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, you can consult the state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
lun_maps
array[lun_maps]
An array of LUN maps.
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the qtree name (optional), and the base name of the LUN. Valid in POST and PATCH.
os_type
string
The operating system type of the LUN.
Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone.
qos
qos
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
space
space
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • readOnly: 1
self
nvme_subsystem_reference
An NVMe subsystem maintains configuration state and NVMe namespace access control for a set of NVMe-connected hosts.
_links
_links
name
string
The name of the NVMe subsystem.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter.
_links
self_link
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
namespaces
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
comment
string
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, you can check the state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
name
string
The fully qualified path name of the NVMe namespace composed of a "/vol" prefix, the volume name, the (optional) qtree name and base name of the namespace. Valid in POST.
NVMe namespaces do not support rename, or movement between volumes.
os_type
string
The operating system type of the NVMe namespace.
Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone.
subsystem_map
array[subsystem_map]
uuid
string
The unique identifier of the NVMe namespace.
_links
self_link
name
string
The name of the consistency group.
uuid
string
storage_service
Determines the placement of any storage object created during this operation.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
snapshot
A consistency group's Snapshot copy
name
string
The name of the consistency group's Snapshot copy to restore to.
uuid
string
The UUID of the consistency group's Snapshot copy to restore to.
restore_to
snapshot
snapshot
_links
_links
name
string
uuid
string
space
available
integer
The amount of space available in the consistency group, in bytes.
size
integer
The total provisioned size of the consistency group, in bytes.
used
integer
The amount of space consumed in the consistency group, in bytes.
svm_reference
_links
_links
name
string
The name of the SVM.
uuid
string
tiering
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold.
FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH.
all ‐ Allows tiering of both Snapshot copies and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks.
auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store
none ‐ Volume blocks are not be tiered to the cloud store.
snapshot_only ‐ Allows tiering of only the volume Snapshot copies not associated with the active file system.
The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days.
qos
The QoS policy for this volume.
policy
policy
The QoS policy
space
available
integer
The available space, in bytes.
size
integer
Total provisioned size, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
tiering
The tiering placement and policy definitions for this volume.
policy
string
volumes
comment
string
A comment for the volume. Valid in POST or PATCH.
language
string
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
qos
qos
snapshot_policy
space
space
tiering
tiering
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.8
consistency_groups
_links
self_link
luns
array[luns]
name
string
namespaces
array[namespaces]
  • maxItems: 16
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
space
space
svm
svm_reference
tiering
tiering
uuid
string
  • readOnly: 1
volumes
array[volumes]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
