REST API reference
Retrieve a consistency group
GET /application/consistency-groups/{uuid}
Introduced In: 9.10
Retrieves a single consistency group.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
  • volumes
  • luns
  • namespaces
  • vserver consistency-group show
uuid
string
path
True
The unique identifier of the group to retrieve.
application.component_type
string
query
False
Filter by application.component_type
  • Introduced in: 9.12
application.type
string
query
False
Filter by application.type
tiering.policy
string
query
False
Filter by tiering.policy
luns.create_time
string
query
False
Filter by luns.create_time
luns.comment
string
query
False
Filter by luns.comment
  • maxLength: 254
  • minLength: 0
luns.os_type
string
query
False
Filter by luns.os_type
luns.uuid
string
query
False
Filter by luns.uuid
luns.space.used
integer
query
False
Filter by luns.space.used
luns.space.guarantee.requested
boolean
query
False
Filter by luns.space.guarantee.requested
  • Introduced in: 9.11
luns.space.guarantee.reserved
boolean
query
False
Filter by luns.space.guarantee.reserved
luns.space.snapshot.reserve_available
integer
query
False
Filter by luns.space.snapshot.reserve_available
  • Introduced in: 9.18
luns.space.snapshot.reserve_percent
integer
query
False
Filter by luns.space.snapshot.reserve_percent
luns.space.snapshot.space_used_percent
integer
query
False
Filter by luns.space.snapshot.space_used_percent
luns.space.snapshot.used
integer
query
False
Filter by luns.space.snapshot.used
luns.space.snapshot.reserve_size
integer
query
False
Filter by luns.space.snapshot.reserve_size
luns.space.snapshot.autodelete.enabled
boolean
query
False
Filter by luns.space.snapshot.autodelete.enabled
luns.space.size
integer
query
False
Filter by luns.space.size
  • Max value: 140737488355328
  • Min value: 4096
luns.serial_number
string
query
False
Filter by luns.serial_number
  • maxLength: 12
  • minLength: 12
luns.qos.policy.min_throughput_iops
integer
query
False
Filter by luns.qos.policy.min_throughput_iops
  • Max value: 2147483647
  • Min value: 0
luns.qos.policy.uuid
string
query
False
Filter by luns.qos.policy.uuid
luns.qos.policy.max_throughput_mbps
integer
query
False
Filter by luns.qos.policy.max_throughput_mbps
  • Max value: 4194303
  • Min value: 0
luns.qos.policy.name
string
query
False
Filter by luns.qos.policy.name
luns.qos.policy.min_throughput_mbps
integer
query
False
Filter by luns.qos.policy.min_throughput_mbps
  • Min value: 0
luns.qos.policy.max_throughput_iops
integer
query
False
Filter by luns.qos.policy.max_throughput_iops
  • Min value: 0
luns.name
string
query
False
Filter by luns.name
luns.enabled
boolean
query
False
Filter by luns.enabled
luns.lun_maps.logical_unit_number
integer
query
False
Filter by luns.lun_maps.logical_unit_number
luns.lun_maps.igroup.igroups.uuid
string
query
False
Filter by luns.lun_maps.igroup.igroups.uuid
luns.lun_maps.igroup.igroups.name
string
query
False
Filter by luns.lun_maps.igroup.igroups.name
  • maxLength: 96
  • minLength: 1
luns.lun_maps.igroup.uuid
string
query
False
Filter by luns.lun_maps.igroup.uuid
luns.lun_maps.igroup.protocol
string
query
False
Filter by luns.lun_maps.igroup.protocol
luns.lun_maps.igroup.name
string
query
False
Filter by luns.lun_maps.igroup.name
  • maxLength: 96
  • minLength: 1
luns.lun_maps.igroup.os_type
string
query
False
Filter by luns.lun_maps.igroup.os_type
luns.lun_maps.igroup.comment
string
query
False
Filter by luns.lun_maps.igroup.comment
  • maxLength: 254
  • minLength: 0
luns.lun_maps.igroup.initiators.name
string
query
False
Filter by luns.lun_maps.igroup.initiators.name
luns.lun_maps.igroup.initiators.comment
string
query
False
Filter by luns.lun_maps.igroup.initiators.comment
  • maxLength: 254
  • minLength: 0
statistics.timestamp
string
query
False
Filter by statistics.timestamp
  • Introduced in: 9.13
statistics.used_space
integer
query
False
Filter by statistics.used_space
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.status
string
query
False
Filter by statistics.status
statistics.available_space
integer
query
False
Filter by statistics.available_space
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.size
integer
query
False
Filter by statistics.size
snapshot_policy.uuid
string
query
False
Filter by snapshot_policy.uuid
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
replication_source
boolean
query
False
Filter by replication_source
name
string
query
False
Filter by name
replicated
boolean
query
False
Filter by replicated
clone.guarantee.type
string
query
False
Filter by clone.guarantee.type
clone.parent_snapshot.name
string
query
False
Filter by clone.parent_snapshot.name
clone.parent_snapshot.uuid
string
query
False
Filter by clone.parent_snapshot.uuid
  • Introduced in: 9.15
clone.parent_svm.name
string
query
False
Filter by clone.parent_svm.name
clone.parent_svm.uuid
string
query
False
Filter by clone.parent_svm.uuid
clone.volume.suffix
string
query
False
Filter by clone.volume.suffix
clone.volume.prefix
string
query
False
Filter by clone.volume.prefix
clone.split_complete_percent
integer
query
False
Filter by clone.split_complete_percent
clone.parent_consistency_group.name
string
query
False
Filter by clone.parent_consistency_group.name
clone.parent_consistency_group.uuid
string
query
False
Filter by clone.parent_consistency_group.uuid
clone.is_flexclone
boolean
query
False
Filter by clone.is_flexclone
clone.split_initiated
boolean
query
False
Filter by clone.split_initiated
clone.split_estimate
integer
query
False
Filter by clone.split_estimate
metric.size
integer
query
False
Filter by metric.size
metric.duration
string
query
False
Filter by metric.duration
metric.available_space
integer
query
False
Filter by metric.available_space
metric.status
string
query
False
Filter by metric.status
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.throughput.other
integer
query
False
Filter by metric.throughput.other
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.used_space
integer
query
False
Filter by metric.used_space
consistency_groups.uuid
string
query
False
Filter by consistency_groups.uuid
consistency_groups.space.used
integer
query
False
Filter by consistency_groups.space.used
consistency_groups.space.size
integer
query
False
Filter by consistency_groups.space.size
consistency_groups.space.available
integer
query
False
Filter by consistency_groups.space.available
consistency_groups.snapshot_policy.uuid
string
query
False
Filter by consistency_groups.snapshot_policy.uuid
consistency_groups.snapshot_policy.name
string
query
False
Filter by consistency_groups.snapshot_policy.name
consistency_groups.luns.create_time
string
query
False
Filter by consistency_groups.luns.create_time
consistency_groups.luns.comment
string
query
False
Filter by consistency_groups.luns.comment
  • maxLength: 254
  • minLength: 0
consistency_groups.luns.os_type
string
query
False
Filter by consistency_groups.luns.os_type
consistency_groups.luns.uuid
string
query
False
Filter by consistency_groups.luns.uuid
consistency_groups.luns.space.used
integer
query
False
Filter by consistency_groups.luns.space.used
consistency_groups.luns.space.guarantee.requested
boolean
query
False
Filter by consistency_groups.luns.space.guarantee.requested
consistency_groups.luns.space.guarantee.reserved
boolean
query
False
Filter by consistency_groups.luns.space.guarantee.reserved
consistency_groups.luns.space.snapshot.reserve_available
integer
query
False
Filter by consistency_groups.luns.space.snapshot.reserve_available
consistency_groups.luns.space.snapshot.reserve_percent
integer
query
False
Filter by consistency_groups.luns.space.snapshot.reserve_percent
consistency_groups.luns.space.snapshot.space_used_percent
integer
query
False
Filter by consistency_groups.luns.space.snapshot.space_used_percent
consistency_groups.luns.space.snapshot.used
integer
query
False
Filter by consistency_groups.luns.space.snapshot.used
consistency_groups.luns.space.snapshot.reserve_size
integer
query
False
Filter by consistency_groups.luns.space.snapshot.reserve_size
consistency_groups.luns.space.snapshot.autodelete.enabled
boolean
query
False
Filter by consistency_groups.luns.space.snapshot.autodelete.enabled
consistency_groups.luns.space.size
integer
query
False
Filter by consistency_groups.luns.space.size
  • Min value: 4096
consistency_groups.luns.serial_number
string
query
False
Filter by consistency_groups.luns.serial_number
  • maxLength: 12
  • minLength: 12
consistency_groups.luns.qos.policy.min_throughput_iops
integer
query
False
Filter by consistency_groups.luns.qos.policy.min_throughput_iops
  • Min value: 0
consistency_groups.luns.qos.policy.uuid
string
query
False
Filter by consistency_groups.luns.qos.policy.uuid
consistency_groups.luns.qos.policy.max_throughput_mbps
integer
query
False
Filter by consistency_groups.luns.qos.policy.max_throughput_mbps
  • Min value: 0
consistency_groups.luns.qos.policy.name
string
query
False
Filter by consistency_groups.luns.qos.policy.name
consistency_groups.luns.qos.policy.min_throughput_mbps
integer
query
False
Filter by consistency_groups.luns.qos.policy.min_throughput_mbps
  • Min value: 0
consistency_groups.luns.qos.policy.max_throughput_iops
integer
query
False
Filter by consistency_groups.luns.qos.policy.max_throughput_iops
  • Min value: 0
consistency_groups.luns.name
string
query
False
Filter by consistency_groups.luns.name
consistency_groups.luns.enabled
boolean
query
False
Filter by consistency_groups.luns.enabled
consistency_groups.luns.lun_maps.logical_unit_number
integer
query
False
Filter by consistency_groups.luns.lun_maps.logical_unit_number
consistency_groups.luns.lun_maps.igroup.igroups.uuid
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.igroups.uuid
consistency_groups.luns.lun_maps.igroup.igroups.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.igroups.name
  • maxLength: 96
  • minLength: 1
consistency_groups.luns.lun_maps.igroup.uuid
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.uuid
consistency_groups.luns.lun_maps.igroup.protocol
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.protocol
consistency_groups.luns.lun_maps.igroup.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.name
  • maxLength: 96
  • minLength: 1
consistency_groups.luns.lun_maps.igroup.os_type
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.os_type
consistency_groups.luns.lun_maps.igroup.comment
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.comment
  • maxLength: 254
  • minLength: 0
consistency_groups.luns.lun_maps.igroup.initiators.name
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.initiators.name
consistency_groups.luns.lun_maps.igroup.initiators.comment
string
query
False
Filter by consistency_groups.luns.lun_maps.igroup.initiators.comment
  • maxLength: 254
  • minLength: 0
consistency_groups.tiering.policy
string
query
False
Filter by consistency_groups.tiering.policy
consistency_groups.application.type
string
query
False
Filter by consistency_groups.application.type
consistency_groups.application.component_type
string
query
False
Filter by consistency_groups.application.component_type
consistency_groups.name
string
query
False
Filter by consistency_groups.name
consistency_groups.parent_consistency_group.uuid
string
query
False
Filter by consistency_groups.parent_consistency_group.uuid
consistency_groups.parent_consistency_group.name
string
query
False
Filter by consistency_groups.parent_consistency_group.name
consistency_groups.volumes.nas.junction_parent.name
string
query
False
Filter by consistency_groups.volumes.nas.junction_parent.name
consistency_groups.volumes.nas.junction_parent.uuid
string
query
False
Filter by consistency_groups.volumes.nas.junction_parent.uuid
consistency_groups.volumes.nas.security_style
string
query
False
Filter by consistency_groups.volumes.nas.security_style
consistency_groups.volumes.nas.uid
integer
query
False
Filter by consistency_groups.volumes.nas.uid
consistency_groups.volumes.nas.gid
integer
query
False
Filter by consistency_groups.volumes.nas.gid
consistency_groups.volumes.nas.export_policy.name
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.name
consistency_groups.volumes.nas.export_policy.rules.index
integer
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.index
consistency_groups.volumes.nas.export_policy.rules.clients.match
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.clients.match
consistency_groups.volumes.nas.export_policy.rules.chown_mode
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.chown_mode
consistency_groups.volumes.nas.export_policy.rules.ntfs_unix_security
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.ntfs_unix_security
consistency_groups.volumes.nas.export_policy.rules.allow_suid
boolean
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.allow_suid
consistency_groups.volumes.nas.export_policy.rules.superuser
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.superuser
consistency_groups.volumes.nas.export_policy.rules.ro_rule
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.ro_rule
consistency_groups.volumes.nas.export_policy.rules.protocols
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.protocols
consistency_groups.volumes.nas.export_policy.rules.anonymous_user
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.anonymous_user
consistency_groups.volumes.nas.export_policy.rules.allow_device_creation
boolean
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.allow_device_creation
consistency_groups.volumes.nas.export_policy.rules.rw_rule
string
query
False
Filter by consistency_groups.volumes.nas.export_policy.rules.rw_rule
consistency_groups.volumes.nas.export_policy.id
integer
query
False
Filter by consistency_groups.volumes.nas.export_policy.id
  • Introduced in: 9.14
consistency_groups.volumes.nas.cifs.shares.namespace_caching
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.namespace_caching
consistency_groups.volumes.nas.cifs.shares.continuously_available
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.continuously_available
consistency_groups.volumes.nas.cifs.shares.vscan_profile
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.vscan_profile
consistency_groups.volumes.nas.cifs.shares.acls.type
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.acls.type
consistency_groups.volumes.nas.cifs.shares.acls.user_or_group
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.acls.user_or_group
consistency_groups.volumes.nas.cifs.shares.acls.permission
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.acls.permission
consistency_groups.volumes.nas.cifs.shares.acls.win_sid_unix_id
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.acls.win_sid_unix_id
  • Introduced in: 9.16
consistency_groups.volumes.nas.cifs.shares.offline_files
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.offline_files
consistency_groups.volumes.nas.cifs.shares.home_directory
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.home_directory
consistency_groups.volumes.nas.cifs.shares.allow_unencrypted_access
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.allow_unencrypted_access
consistency_groups.volumes.nas.cifs.shares.encryption
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.encryption
consistency_groups.volumes.nas.cifs.shares.comment
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.comment
  • maxLength: 256
  • minLength: 1
consistency_groups.volumes.nas.cifs.shares.dir_umask
integer
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.dir_umask
consistency_groups.volumes.nas.cifs.shares.oplocks
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.oplocks
consistency_groups.volumes.nas.cifs.shares.show_snapshot
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.show_snapshot
consistency_groups.volumes.nas.cifs.shares.change_notify
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.change_notify
consistency_groups.volumes.nas.cifs.shares.access_based_enumeration
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.access_based_enumeration
string
query
False
  • maxLength: 80
  • minLength: 1
consistency_groups.volumes.nas.cifs.shares.file_umask
integer
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.file_umask
consistency_groups.volumes.nas.cifs.shares.no_strict_security
boolean
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.no_strict_security
consistency_groups.volumes.nas.cifs.shares.unix_symlink
string
query
False
Filter by consistency_groups.volumes.nas.cifs.shares.unix_symlink
consistency_groups.volumes.nas.path
string
query
False
Filter by consistency_groups.volumes.nas.path
consistency_groups.volumes.nas.unix_permissions
integer
query
False
Filter by consistency_groups.volumes.nas.unix_permissions
consistency_groups.volumes.comment
string
query
False
Filter by consistency_groups.volumes.comment
  • maxLength: 1023
  • minLength: 0
consistency_groups.volumes.uuid
string
query
False
Filter by consistency_groups.volumes.uuid
consistency_groups.volumes.space.available
integer
query
False
Filter by consistency_groups.volumes.space.available
consistency_groups.volumes.space.size
integer
query
False
Filter by consistency_groups.volumes.space.size
consistency_groups.volumes.space.used
integer
query
False
Filter by consistency_groups.volumes.space.used
consistency_groups.volumes.snapshot_policy.uuid
string
query
False
Filter by consistency_groups.volumes.snapshot_policy.uuid
consistency_groups.volumes.snapshot_policy.name
string
query
False
Filter by consistency_groups.volumes.snapshot_policy.name
consistency_groups.volumes.tiering.policy
string
query
False
Filter by consistency_groups.volumes.tiering.policy
consistency_groups.volumes.qos.policy.name
string
query
False
Filter by consistency_groups.volumes.qos.policy.name
consistency_groups.volumes.qos.policy.uuid
string
query
False
Filter by consistency_groups.volumes.qos.policy.uuid
consistency_groups.volumes.name
string
query
False
Filter by consistency_groups.volumes.name
  • maxLength: 203
  • minLength: 1
consistency_groups._tags
string
query
False
Filter by consistency_groups._tags
consistency_groups.qos.policy.name
string
query
False
Filter by consistency_groups.qos.policy.name
consistency_groups.qos.policy.uuid
string
query
False
Filter by consistency_groups.qos.policy.uuid
consistency_groups.namespaces.create_time
string
query
False
Filter by consistency_groups.namespaces.create_time
consistency_groups.namespaces.subsystem_map.nsid
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.nsid
consistency_groups.namespaces.subsystem_map.subsystem.hosts.tls.key_type
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.tls.key_type
consistency_groups.namespaces.subsystem_map.subsystem.hosts.nqn
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.nqn
consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.group_size
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.group_size
consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.hash_function
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.hash_function
consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.mode
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.mode
consistency_groups.namespaces.subsystem_map.subsystem.hosts.priority
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.priority
consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.local_svm
boolean
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.local_svm
  • Introduced in: 9.17
consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.name
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.name
consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.uuid
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.uuid
consistency_groups.namespaces.subsystem_map.subsystem.uuid
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.uuid
consistency_groups.namespaces.subsystem_map.subsystem.comment
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.comment
  • maxLength: 255
  • minLength: 0
consistency_groups.namespaces.subsystem_map.subsystem.os_type
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.os_type
consistency_groups.namespaces.subsystem_map.subsystem.name
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.subsystem.name
  • maxLength: 64
  • minLength: 1
consistency_groups.namespaces.subsystem_map.anagrpid
string
query
False
Filter by consistency_groups.namespaces.subsystem_map.anagrpid
consistency_groups.namespaces.os_type
string
query
False
Filter by consistency_groups.namespaces.os_type
consistency_groups.namespaces.comment
string
query
False
Filter by consistency_groups.namespaces.comment
  • maxLength: 254
  • minLength: 0
consistency_groups.namespaces.uuid
string
query
False
Filter by consistency_groups.namespaces.uuid
consistency_groups.namespaces.space.snapshot.reserve_available
integer
query
False
Filter by consistency_groups.namespaces.space.snapshot.reserve_available
consistency_groups.namespaces.space.snapshot.reserve_percent
integer
query
False
Filter by consistency_groups.namespaces.space.snapshot.reserve_percent
consistency_groups.namespaces.space.snapshot.space_used_percent
integer
query
False
Filter by consistency_groups.namespaces.space.snapshot.space_used_percent
consistency_groups.namespaces.space.snapshot.used
integer
query
False
Filter by consistency_groups.namespaces.space.snapshot.used
consistency_groups.namespaces.space.snapshot.reserve_size
integer
query
False
Filter by consistency_groups.namespaces.space.snapshot.reserve_size
consistency_groups.namespaces.space.snapshot.autodelete.enabled
boolean
query
False
Filter by consistency_groups.namespaces.space.snapshot.autodelete.enabled
consistency_groups.namespaces.space.size
integer
query
False
Filter by consistency_groups.namespaces.space.size
  • Min value: 4096
consistency_groups.namespaces.space.guarantee.reserved
boolean
query
False
Filter by consistency_groups.namespaces.space.guarantee.reserved
consistency_groups.namespaces.space.guarantee.requested
boolean
query
False
Filter by consistency_groups.namespaces.space.guarantee.requested
consistency_groups.namespaces.space.used
integer
query
False
Filter by consistency_groups.namespaces.space.used
consistency_groups.namespaces.space.block_size
integer
query
False
Filter by consistency_groups.namespaces.space.block_size
consistency_groups.namespaces.name
string
query
False
Filter by consistency_groups.namespaces.name
consistency_groups.namespaces.auto_delete
boolean
query
False
Filter by consistency_groups.namespaces.auto_delete
consistency_groups.namespaces.status.container_state
string
query
False
Filter by consistency_groups.namespaces.status.container_state
consistency_groups.namespaces.status.mapped
boolean
query
False
Filter by consistency_groups.namespaces.status.mapped
consistency_groups.namespaces.status.read_only
boolean
query
False
Filter by consistency_groups.namespaces.status.read_only
consistency_groups.namespaces.status.state
string
query
False
Filter by consistency_groups.namespaces.status.state
consistency_groups.namespaces.enabled
boolean
query
False
Filter by consistency_groups.namespaces.enabled
consistency_groups.svm.name
string
query
False
Filter by consistency_groups.svm.name
consistency_groups.svm.uuid
string
query
False
Filter by consistency_groups.svm.uuid
replication_relationships.is_protected_by_svm_dr
boolean
query
False
Filter by replication_relationships.is_protected_by_svm_dr
replication_relationships.uuid
string
query
False
Filter by replication_relationships.uuid
replication_relationships.is_source
boolean
query
False
Filter by replication_relationships.is_source
space.used
integer
query
False
Filter by space.used
space.size
integer
query
False
Filter by space.size
space.available
integer
query
False
Filter by space.available
qos.policy.name
string
query
False
Filter by qos.policy.name
qos.policy.uuid
string
query
False
Filter by qos.policy.uuid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
string
query
False
Filter by namespaces.create_time
string
query
False
Filter by namespaces.subsystem_map.nsid
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.tls.key_type
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.nqn
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.group_size
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.hash_function
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.dh_hmac_chap.mode
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.priority
boolean
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.proximity.local_svm
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.name
string
query
False
Filter by namespaces.subsystem_map.subsystem.hosts.proximity.peer_svms.uuid
string
query
False
Filter by namespaces.subsystem_map.subsystem.uuid
string
query
False
Filter by namespaces.subsystem_map.subsystem.comment
  • maxLength: 255
  • minLength: 0
string
query
False
Filter by namespaces.subsystem_map.subsystem.os_type
string
query
False
Filter by namespaces.subsystem_map.subsystem.name
  • maxLength: 64
  • minLength: 1
string
query
False
Filter by namespaces.subsystem_map.anagrpid
namespaces.os_type
string
query
False
Filter by namespaces.os_type
namespaces.comment
string
query
False
Filter by namespaces.comment
  • maxLength: 254
  • minLength: 0
namespaces.uuid
string
query
False
Filter by namespaces.uuid
integer
query
False
Filter by namespaces.space.snapshot.reserve_available
integer
query
False
Filter by namespaces.space.snapshot.reserve_percent
integer
query
False
Filter by namespaces.space.snapshot.space_used_percent
integer
query
False
Filter by namespaces.space.snapshot.used
integer
query
False
Filter by namespaces.space.snapshot.reserve_size
boolean
query
False
Filter by namespaces.space.snapshot.autodelete.enabled
integer
query
False
Filter by namespaces.space.size
  • Min value: 4096
boolean
query
False
Filter by namespaces.space.guarantee.reserved
boolean
query
False
Filter by namespaces.space.guarantee.requested
integer
query
False
Filter by namespaces.space.used
integer
query
False
Filter by namespaces.space.block_size
namespaces.name
string
query
False
Filter by namespaces.name
boolean
query
False
Filter by namespaces.auto_delete
string
query
False
Filter by namespaces.status.container_state
boolean
query
False
Filter by namespaces.status.mapped
boolean
query
False
Filter by namespaces.status.read_only
string
query
False
Filter by namespaces.status.state
namespaces.enabled
boolean
query
False
Filter by namespaces.enabled
_tags
string
query
False
Filter by _tags
string
query
False
Filter by volumes.nas.junction_parent.name
string
query
False
Filter by volumes.nas.junction_parent.uuid
string
query
False
Filter by volumes.nas.security_style
volumes.nas.uid
integer
query
False
Filter by volumes.nas.uid
volumes.nas.gid
integer
query
False
Filter by volumes.nas.gid
string
query
False
Filter by volumes.nas.export_policy.name
integer
query
False
Filter by volumes.nas.export_policy.rules.index
string
query
False
Filter by volumes.nas.export_policy.rules.clients.match
string
query
False
Filter by volumes.nas.export_policy.rules.chown_mode
string
query
False
Filter by volumes.nas.export_policy.rules.ntfs_unix_security
boolean
query
False
Filter by volumes.nas.export_policy.rules.allow_suid
string
query
False
Filter by volumes.nas.export_policy.rules.superuser
string
query
False
Filter by volumes.nas.export_policy.rules.ro_rule
string
query
False
Filter by volumes.nas.export_policy.rules.protocols
string
query
False
Filter by volumes.nas.export_policy.rules.anonymous_user
boolean
query
False
Filter by volumes.nas.export_policy.rules.allow_device_creation
string
query
False
Filter by volumes.nas.export_policy.rules.rw_rule
integer
query
False
Filter by volumes.nas.export_policy.id
boolean
query
False
Filter by volumes.nas.cifs.shares.namespace_caching
boolean
query
False
Filter by volumes.nas.cifs.shares.continuously_available
string
query
False
Filter by volumes.nas.cifs.shares.vscan_profile
string
query
False
Filter by volumes.nas.cifs.shares.acls.type
string
query
False
Filter by volumes.nas.cifs.shares.acls.user_or_group
string
query
False
Filter by volumes.nas.cifs.shares.acls.permission
string
query
False
Filter by volumes.nas.cifs.shares.acls.win_sid_unix_id
string
query
False
Filter by volumes.nas.cifs.shares.offline_files
boolean
query
False
Filter by volumes.nas.cifs.shares.home_directory
boolean
query
False
Filter by volumes.nas.cifs.shares.allow_unencrypted_access
boolean
query
False
Filter by volumes.nas.cifs.shares.encryption
string
query
False
Filter by volumes.nas.cifs.shares.comment
  • maxLength: 256
  • minLength: 1
integer
query
False
Filter by volumes.nas.cifs.shares.dir_umask
boolean
query
False
Filter by volumes.nas.cifs.shares.oplocks
boolean
query
False
Filter by volumes.nas.cifs.shares.show_snapshot
boolean
query
False
Filter by volumes.nas.cifs.shares.change_notify
boolean
query
False
Filter by volumes.nas.cifs.shares.access_based_enumeration
string
query
False
  • maxLength: 80
  • minLength: 1
integer
query
False
Filter by volumes.nas.cifs.shares.file_umask
boolean
query
False
Filter by volumes.nas.cifs.shares.no_strict_security
string
query
False
Filter by volumes.nas.cifs.shares.unix_symlink
volumes.nas.path
string
query
False
Filter by volumes.nas.path
integer
query
False
Filter by volumes.nas.unix_permissions
volumes.comment
string
query
False
Filter by volumes.comment
  • maxLength: 1023
  • minLength: 0
volumes.uuid
string
query
False
Filter by volumes.uuid
integer
query
False
Filter by volumes.space.available
volumes.space.size
integer
query
False
Filter by volumes.space.size
volumes.space.used
integer
query
False
Filter by volumes.space.used
string
query
False
Filter by volumes.snapshot_policy.uuid
string
query
False
Filter by volumes.snapshot_policy.name
string
query
False
Filter by volumes.tiering.policy
string
query
False
Filter by volumes.qos.policy.name
string
query
False
Filter by volumes.qos.policy.uuid
volumes.name
string
query
False
Filter by volumes.name
  • maxLength: 203
  • minLength: 1
string
query
False
Filter by parent_consistency_group.uuid
string
query
False
Filter by parent_consistency_group.name
vdisk_type
string
query
False
Filter by vdisk_type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
application
application
clone
clone
Creates a clone of an existing consistency group from the current contents or an existing snapshot.
consistency_groups
array[consistency_groups]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A consistency group can only be associated with one direct parent consistency group.
luns
array[luns]
The LUNs array can be used to create or modify LUNs in a consistency group on a new or existing volume that is a member of the consistency group. LUNs are considered members of a consistency group if they are located on a volume that is a member of the consistency group. The maximum number of items for this array is 16.
metric
metric
Performance and capacity numbers, such as, IOPS, latency, throughput, used space, and available space.
name
string
Name of the consistency group. The consistency group name must be unique within an SVM.
If not provided and the consistency group contains only one volume, the name will be generated based on the volume name. If the consistency group contains more than one volume, the name is required.
namespaces
array[namespaces]
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the SVM using the NVMe over Fabrics protocol. In ONTAP, an NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. NVMe namespaces support being cloned. An NVMe namespace cannot be renamed, resized, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace. See the NVMe namespace object model to learn more about each of the properties supported by the NVMe namespace REST API.
An NVMe namespace must be mapped to an NVMe subsystem to grant access to the subsystem's hosts. Hosts can then access the NVMe namespace and perform I/O using the NVMe over Fabrics protocol. The maximum number of items for this array is 16.
  • minItems: 0
  • uniqueItems: 1
  • Introduced in: 9.10
The parent consistency group.
qos
qos
replicated
boolean
Indicates whether or not replication has been enabled on this consistency group.
array[replication_relationships]
Indicates the SnapMirror relationship of this consistency group.
replication_source
boolean
Since support for this field is to be removed in the next release, use replication_relationships.is_source instead.
restore_to
restore_to
Use to restore a consistency group to a previous snapshot
snapshot_policy
snapshot_policy_reference
This is a reference to the snapshot policy.
space
space
Space information for the consistency group.
statistics
statistics
These are raw performance and space numbers, such as, IOPS, latency, throughput, used space, and available space. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
svm
svm
The Storage Virtual Machine (SVM) in which the consistency group is located.
tiering
tiering
The tiering placement and policy definitions for volumes in this consistency group.
uuid
string
The unique identifier of the consistency group. The UUID is generated by ONTAP when the consistency group is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • x-nullable: true
vdisk_type
string
Type of objects in the consistency group.
volumes
array[volumes]
A consistency group is a mutually exclusive aggregation of volumes or other consistency groups. A volume can only be associated with one direct parent consistency group.
The volumes array can be used to create new volumes in the consistency group, add existing volumes to the consistency group, or modify existing volumes that are already members of the consistency group.
The total number of volumes across all child consistency groups contained in a consistency group is constrained by the same limit.
      "href": "/api/resourcelink"
  "_tags": [
    "team:csi",
    "environment:test"
  "application": {
    "component_type": "string",
    "type": "string"
  "clone": {
    "guarantee": {
      "type": "string"
    "parent_consistency_group": {
      "name": "string",
      "uuid": "string"
    "parent_snapshot": {
      "name": "this_snapshot",
    "parent_svm": {
      "name": "svm1",
    "split_complete_percent": 0,
    "split_estimate": 0,
    "volume": {
      "prefix": "string",
      "suffix": "string"
  "consistency_groups": [
      "_tags": [
        "team:csi",
        "environment:test"
      "application": {
        "type": "string"
      "luns": [
          "comment": "string",
          "create_time": "2018-06-04 19:00:00 +0000",
          "lun_maps": [
              "igroup": {
                "igroups": [
                    "name": "igroup1",
                "initiators": [
                    "comment": "my comment",
                    "name": "iqn.1998-01.com.corp.iscsi:name1"
                "name": "igroup1",
                "os_type": "string",
                "protocol": "string",
          "name": "/vol/volume1/lun1",
          "qos": {
            "policy": {
              "max_throughput_iops": 10000,
              "max_throughput_mbps": 500,
              "min_throughput_iops": 2000,
              "min_throughput_mbps": 500,
              "name": "performance",
          "serial_number": "string",
          "space": {
            "size": 1073741824,
            "used": 0
      "name": "string",
      "namespaces": [
          "name": "/vol/volume1/qtree1/namespace1",
          "space": {
            "block_size": 512,
            "size": 1073741824,
            "used": 0
          "status": {
            "container_state": "string",
            "state": "online"
          "subsystem_map": {
            "anagrpid": "00103050h",
            "nsid": "00000001h",
            "subsystem": {
              "hosts": [
                  "dh_hmac_chap": {
                    "group_size": "string",
                    "hash_function": "string",
                    "mode": "bidirectional"
                  "nqn": "nqn.1992-01.example.com:string",
                  "priority": "string",
                  "proximity": {
                    "peer_svms": [
                        "name": "peer1",
                        "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
                  "tls": {
                    "key_type": "configured"
              "name": "subsystem1",
        "name": "my_consistency_group",
      "qos": {
        "policy": {
      "restore_to": {
        "snapshot": {
          "name": "string",
          "uuid": "string"
      "snapshot_policy": {
        "name": "default",
      "space": {
        "available": 5737418,
        "size": 1073741824,
        "used": 5737418
      "svm": {
        "name": "svm1",
      "tiering": {
        "object_stores": [
        "policy": "string"
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volumes": [
          "name": "vol_cs_dept",
          "nas": {
            "cifs": {
              "shares": [
                  "acls": [
                      "permission": "string",
                      "type": "string",
                      "user_or_group": "ENGDOMAIN\\ad_user",
                      "win_sid_unix_id": "string"
                  "comment": "HR Department Share",
                  "dir_umask": 18,
                  "file_umask": 18,
                  "name": "HR_SHARE",
                  "offline_files": "string",
                  "unix_symlink": "string",
                  "vscan_profile": "string"
            "export_policy": {
              "id": 0,
              "name": "string",
              "rules": [
                  "anonymous_user": "string",
                  "chown_mode": "string",
                  "clients": [
                      "match": "0.0.0.0/0"
                  "ntfs_unix_security": "string",
                  "protocols": [
                    "string"
                  "ro_rule": [
                    "string"
                  "rw_rule": [
                    "string"
                  "superuser": [
                    "string"
            "junction_parent": {
              "name": "vs1_root",
              "uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
            "path": "/user/my_volume",
            "security_style": "string",
            "unix_permissions": 493
          "qos": {
            "policy": {
            "name": "default",
          "space": {
            "available": 0,
            "used": 0
          "tiering": {
            "object_stores": [
            "policy": "string"
  "luns": [
      "lun_maps": [
          "igroup": {
            "igroups": [
                "name": "igroup1",
            "initiators": [
            "name": "igroup1",
      "qos": {
        "policy": {
      "space": {
        "size": 1073741824,
        "used": 0
  "metric": {
    "available_space": 4096,
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "size": 4096,
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25 11:20:13 +0000",
    "used_space": 4096
  "name": "string",
  "namespaces": [
      "space": {
        "block_size": 512,
        "size": 1073741824,
        "used": 0
      "status": {
        "state": "online"
      "subsystem_map": {
        "subsystem": {
          "hosts": [
              "dh_hmac_chap": {
              "proximity": {
                "peer_svms": [
                    "name": "peer1",
              "tls": {
  "qos": {
    "policy": {
  "replication_relationships": [
  "restore_to": {
    "snapshot": {
      "name": "string",
      "uuid": "string"
    "name": "default",
  "space": {
    "size": 1073741824,
    "used": 5737418
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "size": 4096,
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "used_space": 4096
  "svm": {
    "name": "svm1",
  "tiering": {
    "object_stores": [
    "policy": "string"
  "vdisk_type": "luns",
  "volumes": [
      "nas": {
        "cifs": {
          "shares": [
              "acls": [
                  "type": "string",
              "dir_umask": 18,
              "file_umask": 18,
              "name": "HR_SHARE",
        "export_policy": {
          "id": 0,
          "name": "string",
          "rules": [
              "clients": [
              "protocols": [
                "string"
              "ro_rule": [
                "string"
              "rw_rule": [
                "string"
              "superuser": [
                "string"
          "name": "vs1_root",
      "qos": {
        "policy": {
        "name": "default",
      "space": {
        "available": 0,
        "used": 0
      "tiering": {
        "object_stores": [
        "policy": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
application
component_type
string
Nested consistency group tag.
type
string
Top level consistency group tag.
guarantee
type
string
The type of space guarantee of this volume in the aggregate.
Consistency group that is to be cloned.
_links
self_link
name
string
The name of the consistency group.
uuid
string
self
parent_snapshot
_links
_links
name
string
uuid
string
parent_svm
_links
_links
name
string
uuid
string
volume
Volume name suffix/prefix for the cloned volumes.
prefix
string
Volume name prefix for cloned volumes.
suffix
string
Volume name suffix for cloned volumes.
clone
guarantee
guarantee
is_flexclone
boolean
Specifies if this consistency group is a FlexClone of a consistency group.
parent_snapshot
parent_snapshot
parent_svm
parent_svm
integer
Percentage of FlexClone blocks split from its parent consistency group.
split_estimate
integer
Space required to split the FlexClone consistency group.
split_initiated
boolean
Splits volumes after cloning. Defaults to false during POST. Only accepts true during a PATCH.
volume
volume
source
The source LUN for a LUN clone operation. This can be specified using property clone.source.uuid or clone.source.name. If both properties are supplied, they must refer to the same LUN.
Valid in POST to create a new LUN as a clone of the source.
Valid in PATCH to overwrite an existing LUN's data as a clone of another.
clone
This sub-object is used in POST to create a new LUN as a clone of an existing LUN, or PATCH to overwrite an existing LUN as a clone of another. Setting a property in this sub-object indicates that a LUN clone is desired. Consider the following other properties when cloning a LUN: auto_delete, qos_policy, space.guarantee.requested and space.scsi_thin_provisioning_support_enabled.
When used in a PATCH, the patched LUN's data is over-written as a clone of the source and the following properties are preserved from the patched LUN unless otherwise specified as part of the PATCH: class, auto_delete, lun_maps, serial_number, status.state, and uuid.
Persistent reservations for the patched LUN are also preserved.
igroups
_links
self_link
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiators
The initiators that are members of the initiator group.
comment
string
A comment available for use by the administrator.
name
string
Name of initiator that is a member of the initiator group.
igroup
The initiator group that directly owns the initiator, which is where modification of the initiator is supported. This property will only be populated when the initiator is a member of a nested initiator group.
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
igroups
array[igroups]
The existing initiator groups that are members of the group. Optional in POST.
This property is mutually exclusive with the initiators property during POST.
This array contains only the direct children of the initiator group. If the member initiator groups have further nested initiator groups, those are reported in the igroups property of the child initiator group.
Zero or more nested initiator groups can be supplied when the initiator group is created. The initiator group will act as if it contains the aggregation of all initiators in any nested initiator groups.
After creation, nested initiator groups can be added or removed from the initiator group using the /protocols/san/igroups/{igroup.uuid}/igroups endpoint. See link:post-protocols-san-igroups-igroups(#-san-igroup-nested-create)anddelete-protocols-san-igroups-igroups-.htmlPOST /protocols/san/igroups/{igroup.uuid}/igroups and [DELETE /protocols/san/igroups/{igroup.uuid}/igroups/{uuid}] for more details.
initiators
array[initiators]
The initiators that are members of the group.
name
string
The name of the initiator group. Required in POST; optional in PATCH.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. Required in POST; optional in PATCH.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. Optional in POST; if not supplied, this defaults to mixed.
The protocol of an initiator group cannot be changed after creation of the group.
uuid
string
lun_maps
A LUN map is an association between a LUN and an initiator group.
When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
igroup
igroup
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through the Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value. This property is not supported when the provisioning_options.count property is 2 or more.
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
Options that are applied to the operation.
action
string
Operation to perform
count
integer
Number of elements to perform the operation on.
policy
The QoS policy
_links
self_link
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
policy
policy
The QoS policy
guarantee
Properties that request and report the space guarantee for the LUN.
requested
boolean
The requested space reservation policy for the LUN. If true, a space reservation is requested for the LUN; if false, the LUN is thin provisioned. Guaranteeing a space reservation request for a LUN requires that the volume in which the LUN resides is also space reserved and that the fractional reserve for the volume is 100%. Valid in POST and PATCH.
reserved
boolean
Reports if the LUN is space guaranteed.
If true, a space guarantee is requested and the containing volume and aggregate support the request. If false, a space guarantee is not requested or a space guarantee is requested and either the containing volume or aggregate do not support the request.
space
The storage space related properties of the LUN.
guarantee
guarantee
size
integer
The total provisioned size of the LUN. The LUN size can be increased but not reduced using the REST interface. The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The actual minimum and maximum sizes vary depending on the ONTAP version, ONTAP platform, and the available space in the containing volume and aggregate. For more information, see Size properties in the docs section of the ONTAP REST API documentation.
  • example: 1073741824
  • format: int64
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the LUN.
This value is the total space consumed in the volume by the LUN, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways SAN filesystems and applications utilize blocks within a LUN, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the LUN blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
luns
A LUN is the logical representation of storage in a storage area network (SAN).
A LUN must be mapped to an initiator group to grant access to the initiator group's initiators (client hosts). Initiators can then access the LUN and perform I/O over a Fibre Channel (FC) fabric using the FC Protocol or a TCP/IP network using iSCSI.
See the LUN object model to learn more about each of the properties supported by the LUN REST API.
A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<lun>" where the qtree name is optional.
A LUN can be created to a specified size using thin or thick provisioning. A LUN can then be renamed, resized, cloned, moved to a different volume and copied. LUNs support the assignment of a QoS policy for performance management or a QoS policy can be assigned to a volume containing one or more LUNs.
comment
string
A configurable comment available for use by the administrator. Valid in POST and PATCH.
create_time
string
The time the LUN was created.
enabled
boolean
The enabled state of the LUN. LUNs can be disabled to prevent access to the LUN. Certain error conditions also cause the LUN to become disabled. If the LUN is disabled, you can consult the state property to determine if the LUN is administratively disabled (offline) or has become disabled as a result of an error. A LUN in an error condition can be brought online by setting the enabled property to true or brought administratively offline by setting the enabled property to false. Upon creation, a LUN is enabled by default. Valid in PATCH.
lun_maps
array[lun_maps]
An array of LUN maps.
A LUN map is an association between a LUN and an initiator group. When a LUN is mapped to an initiator group, the initiator group's initiators are granted access to the LUN. The relationship between a LUN and an initiator group is many LUNs to many initiator groups.
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the qtree name (optional), and the base name of the LUN. Valid in POST and PATCH.
os_type
string
The operating system type of the LUN.
Required in POST when creating a LUN that is not a clone of another. Disallowed in POST when creating a LUN clone.
qos
qos
serial_number
string
The LUN serial number. The serial number is generated by ONTAP when the LUN is created.
  • maxLength: 12
  • minLength: 12
  • readOnly: 1
  • x-nullable: true
space
space
uuid
string
The unique identifier of the LUN. The UUID is generated by ONTAP when the LUN is created.
  • readOnly: 1
  • x-nullable: true
guarantee
Properties that request and report the space guarantee for the NVMe namespace.
requested
boolean
The requested space reservation policy for the NVMe namespace. If true, a space reservation is requested for the namespace; if false, the namespace is thin provisioned. Guaranteeing a space reservation request for a namespace requires that the volume in which the namespace resides also be space reserved and that the fractional reserve for the volume be 100%.
The space reservation policy for an NVMe namespace is determined by ONTAP.
  • x-nullable: true
reserved
boolean
Reports if the NVMe namespace is space guaranteed.
This property is true if a space guarantee is requested and the containing volume and aggregate support the request. This property is false if a space guarantee is not requested or if a space guarantee is requested and either the containing volume and aggregate do not support the request.
space
The storage space related properties of the NVMe namespace.
block_size
integer
The size of blocks in the namespace, in bytes.
Valid in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone. Valid in POST.
guarantee
guarantee
size
integer
The total provisioned size of the NVMe namespace. Valid in POST and PATCH. The NVMe namespace size can be increased but not reduced using the REST interface.
The maximum and minimum sizes listed here are the absolute maximum and absolute minimum sizes, in bytes. The maximum size is variable with respect to large NVMe namespace support in ONTAP. If large namespaces are supported, the maximum size is 128 TB (140737488355328 bytes) and if not supported, the maximum size is just under 16 TB (17557557870592 bytes). The minimum size supported is always 4096 bytes.
  • format: int64
  • Min value: 4096
  • x-nullable: true
used
integer
The amount of space consumed by the main data stream of the NVMe namespace.
This value is the total space consumed in the volume by the NVMe namespace, including filesystem overhead, but excluding prefix and suffix streams. Due to internal filesystem overhead and the many ways NVMe filesystems and applications utilize blocks within a namespace, this value does not necessarily reflect actual consumption/availability from the perspective of the filesystem or application. Without specific knowledge of how the namespace blocks are utilized outside of ONTAP, this property should not be used as an indicator for an out-of-space condition.
  • format: int64
  • readOnly: 1
  • x-nullable: true
status
Status information about the NVMe namespace.
container_state
string
The state of the volume and aggregate that contain the NVMe namespace. Namespaces are only available when their containers are available.
mapped
boolean
Reports if the NVMe namespace is mapped to an NVMe subsystem.
There is an added computational cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
read_only
boolean
Reports if the NVMe namespace allows only read access.
state
string
The state of the NVMe namespace. Normal states for a namespace are online and offline. Other states indicate errors.
consistency_group_nvme_host_dh_hmac_chap
A container for the configuration of NVMe in-band authentication using the DH-HMAC-CHAP protocol for a host.
group_size
string
The Diffie-Hellman group size for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to 2048_bit. When supplied, the property host_secret_key must also be supplied. Optional in POST.
hash_function
string
The hash function for NVMe in-band authentication. When property host_secret_key is provided, this property defaults to sha_256. When supplied, the property host_secret_key must also be supplied. Optional in POST.
mode
string
The expected NVMe in-band authentication mode for the host. This property is an indication of which secrets are configured for the host. When set to:
  • none: The host has neither the host nor controller secret configured, and no authentication is performed.
  • unidirectional: The host has a host secret configured. The controller will authenticate the host.
  • bidirectional: The host has both a host and controller secret configured. The controller will authenticate the host and the host will authenticate the controller.
peer_svms
A reference to an SVM peer relationship.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define the SVMs to which the host is proximal. This information is used to properly report active optimized and active non-optimized network paths using an NVMe controller. If no configuration has been specified for the host, the sub-object is not present in GET requests.
These properties apply to all instances of the host in the NVMe subsystem in the SVM and its peers.
local_svm
boolean
A boolean that indicates if the host is proximal to the SVM for which it is configured.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the host is proximal.
tls
A container for the configuration for NVMe/TCP-TLS transport session for the host.
key_type
string
The method by which the TLS pre-shared key (PSK) is configured for the host. Optional in POST.
The values for property key_type and property configured_psk must logically agree.
Possible values:
  • none - TLS is not configured for the host connection. No value is allowed for property configured_psk.
  • configured - A user supplied PSK is configured for the NVMe/TCP-TLS transport connection between the host and the NVMe subsystem. A valid value for property configured_psk is required.
This property defaults to none unless a value is supplied for configured_psk in which case it defaults to configured.
The NVMe host provisioned to access NVMe namespaces mapped to a subsystem.
dh_hmac_chap
nqn
string
The NVMe qualified name (NQN) used to identify the NVMe storage target.
priority
string
The host priority setting allocates appropriate NVMe I/O queues (count and depth) for the host to submit I/O commands. Absence of this property in GET implies io_queue count and I/O queue depth are being used.
proximity
proximity
tls
tls
consistency_group_nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
comment
string
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.
hosts
array[consistency_group_nvme_host]
The NVMe hosts configured for access to the NVMe subsystem. Optional in POST.
name
string
The name of the NVMe subsystem. Once created, an NVMe subsystem cannot be renamed. Required in POST.
os_type
string
The host operating system of the NVMe subsystem's hosts. Required in POST.
uuid
string
The unique identifier of the NVMe subsystem.
subsystem_map
The NVMe subsystem with which the NVMe namespace is associated. A namespace can be mapped to zero (0) or one (1) subsystems.
There is an added computational cost to retrieving property values for subsystem_map. They are not populated for either a collection GET or an instance GET unless explicitly requested using the fields query parameter.
_links
self_link
anagrpid
string
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace.
The format for an ANAGRPID is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
nsid
string
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace.
The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".
subsystem
namespaces
An NVMe namespace is a collection of addressable logical blocks presented to hosts connected to the storage virtual machine using the NVMe over Fabrics protocol.
An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
An NVMe namespace is created to a specified size using thin or thick provisioning as determined by the volume on which it is created. An NVMe namespace can then be resized or cloned. An NVMe namespace cannot be renamed, or moved to a different volume. NVMe namespaces do not support the assignment of a QoS policy for performance management, but a QoS policy can be assigned to the volume containing the namespace.
auto_delete
boolean
This property marks the NVMe namespace for auto deletion when the volume containing the namespace runs out of space. This is most commonly set on namespace clones.
When set to true, the NVMe namespace becomes eligible for automatic deletion when the volume runs out of space. Auto deletion only occurs when the volume containing the namespace is also configured for auto deletion and free space in the volume decreases below a particular threshold.
This property is optional in POST and PATCH. The default value for a new NVMe namespace is false.
comment
string
create_time
string
The time the NVMe namespace was created.
enabled
boolean
The enabled state of the NVMe namespace. Certain error conditions cause the namespace to become disabled. If the namespace is disabled, check the status.state property to determine what error disabled the namespace. An NVMe namespace is enabled automatically when it is created.
name
string
The name of the NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
Renaming an NVMe namespace is not supported. Valid in POST.
os_type
string
The operating system type of the NVMe namespace.
Required in POST when creating an NVMe namespace that is not a clone of another. Disallowed in POST when creating a namespace clone.
space
space
status
status
subsystem_map
subsystem_map
uuid
string
The unique identifier of the NVMe namespace.
_links
self_link
name
string
uuid
string
storage_service
Determines the placement of any storage object created during this operation.
name
string
Storage service name. If not specified, the default value is the most performant for the platform.
action
string
name
string
New name for consistency group. Required to resolve naming collisions.
storage_service
storage_service
policy
The QoS policy
_links
self_link
name
string
uuid
string
snapshot
A consistency group's snapshot
name
string
The name of the consistency group's snapshot to restore to.
uuid
string
The UUID of the consistency group's snapshot to restore to.
restore_to
snapshot
snapshot
_links
_links
name
string
uuid
string
space
available
integer
The amount of space available in the consistency group, in bytes.
size
integer
The total provisioned size of the consistency group, in bytes.
used
integer
The amount of space consumed in the consistency group, in bytes.
svm
_links
_links
name
string
uuid
string
object_stores
tiering
object_stores
array[object_stores]
Object stores to use. Used for placement.
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold.
FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH.
all ‐ Allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks.
auto ‐ Allows tiering of both snapshot and active file system user data to the cloud store
none ‐ Volume blocks are not be tiered to the cloud store.
snapshot_only ‐ Allows tiering of only the volume snapshots not associated with the active file system.
The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy it is 31 days.
acls
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
type
string
Specifies the type of the user or group to add to the access control list of a CIFS share. The following values are allowed:
  • windows - Windows user or group
  • unix_user - UNIX user
  • unix_group - UNIX group
user_or_group
string
Specifies the user or group name to add to the access control list of a CIFS share.
win_sid_unix_id
string
Windows SID/UNIX ID depending on access-control type.
consistency_group_cifs_share
CIFS share is a named access point in a volume. Before users and applications can access data on the CIFS server over SMB, a CIFS share must be created with sufficient share permission. CIFS shares are tied to the CIFS server on the SVM. When a CIFS share is created, ONTAP creates a default ACL for the share with Full Control permissions for Everyone.
_links
_links
boolean
Specifies whether all folders inside this share are visible to a user based on that individual user's access right; prevents the display of folders or other shared resources that the user does not have access to.
acls
array[acls]
boolean
Specifies whether or not the SMB2 clients are allowed to access the encrypted share.
change_notify
boolean
Specifies whether CIFS clients can request for change notifications for directories on this share.
comment
string
Specify the CIFS share descriptions.
boolean
Specifies whether or not the clients connecting to this share can open files in a persistent manner. Files opened in this way are protected from disruptive events, such as, failover and giveback. If the Vscan ONTAP feature is used, it is not supported in continuous availability (CA) shares.
  • Default value: 1
  • Introduced in: 9.12
  • x-nullable: true
dir_umask
integer
Directory mode creation mask to be viewed as an octal number.
encryption
boolean
Specifies whether SMB encryption must be used when accessing this share. Clients that do not support encryption are not able to access this share.
file_umask
integer
File mode creation mask to be viewed as an octal number.
home_directory
boolean
Specifies whether or not the share is a home directory share, where the share and path names are dynamic. ONTAP home directory functionality automatically offer each user a dynamic share to their home directory without creating an individual SMB share for each user. The ONTAP CIFS home directory feature enable us to configure a share that maps to different directories based on the user that connects to it. Instead of creating a separate shares for each user, a single share with a home directory parameters can be created. In a home directory share, ONTAP dynamically generates the share-name and share-path by substituting %w, %u, and %d variables with the corresponding Windows user name, UNIX user name, and domain name, respectively.
  • Default value: 1
  • readCreate: 1
  • x-nullable: true
name
string
Specifies the name of the CIFS share that you want to create. If this is a home directory share then the share name includes the pattern as %w (Windows user name), %u (UNIX user name) and %d (Windows domain name) variables in any combination with this parameter to generate shares dynamically.
namespace_caching
boolean
Specifies whether or not the SMB clients connecting to this share can cache the directory enumeration results returned by the CIFS servers.
no_strict_security
boolean
Specifies whether or not CIFS clients can follow Unix symlinks outside the share boundaries.
offline_files
string
Offline Files The supported values are:
  • none - Clients are not permitted to cache files for offline access.
  • manual - Clients may cache files that are explicitly selected by the user for offline access.
  • documents - Clients may automatically cache files that are used by the user for offline access.
  • programs - Clients may automatically cache files that are used by the user for offline access and may use those files in an offline mode even if the share is available.
oplocks
boolean
Specifies whether opportunistic locks are enabled on this share. "Oplocks" allow clients to lock files and cache content locally, which can increase performance for file operations.
show_snapshot
boolean
Specifies whether or not the snapshots can be viewed and traversed by clients.
unix_symlink
string
Controls the access of UNIX symbolic links to CIFS clients. The supported values are:
  • local - Enables only local symbolic links which is within the same CIFS share.
  • widelink - Enables both local symlinks and widelinks.
  • disable - Disables local symlinks and widelinks.
vscan_profile
string
Vscan File-Operations Profile The supported values are:
  • no_scan - Virus scans are never triggered for accesses to this share.
  • standard - Virus scans can be triggered by open, close, and rename operations.
  • strict - Virus scans can be triggered by open, read, close, and rename operations.
  • writes_only - Virus scans can be triggered only when a file that has been modified is closed.
cifs
shares
array[consistency_group_cifs_share]
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
_links
_links
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
export_policy
The policy associated with volumes to export them for protocol access.
_links
self_link
id
integer
Identifier for the export policy.
name
string
Name of the export policy.
rules
array[export_rules]
The set of rules that govern the export policy.
junction_parent
_links
self_link
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
The CIFS share policy and/or export policies for this volume.
cifs
cifs
export_policy
export_policy
gid
integer
The UNIX group ID of the volume. Valid in POST or PATCH.
junction_parent
junction_parent
path
string
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within an SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted.
security_style
string
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ UNIX-style security.
uid
integer
The UNIX user ID of the volume. Valid in POST or PATCH.
unix_permissions
integer
UNIX permissions to be viewed as an octal number, consisting of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). First digit selects the set user ID (4), set group ID (2), and sticky (1) attributes. Second digit selects permission for the owner of the file. Third selects permissions for other users in the same group while the fourth selects permissions for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group, and other permissions are given (as in 755, representing the second, third and fourth digit), the first digit is assumed to be zero.
action
string
count
integer
storage_service
storage_service
qos
The QoS policy for this volume.
policy
policy
The QoS policy
space
available
integer
The available space, in bytes.
size
integer
Total provisioned size, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
tiering
The tiering placement and policy definitions for this volume.
object_stores
policy
string
volumes
comment
string
A comment for the volume. Valid in POST or PATCH.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
qos
qos
snapshot_policy
space
space
tiering
tiering
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
consistency_groups
_links
self_link
_tags
array[string]
application
application
luns
array[luns]
name
string
namespaces
array[namespaces]
  • minItems: 0
  • uniqueItems: 1
qos
qos
restore_to
restore_to
snapshot_policy
space
space
svm
svm
tiering
tiering
uuid
string
  • readOnly: 1
  • x-nullable: true
volumes
array[volumes]
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
The round trip latency observed at the storage object, in microseconds.
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
_links
_links
available_space
integer
The total space available in the consistency group, in bytes.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
size
integer
The total size of the consistency group, in bytes.
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance and capacity data.
used_space
integer
The total space used in the consistency group, in bytes.
_links
self_link
boolean
Indicates whether or not this consistency group is protected by SVM DR.
is_source
boolean
Indicates whether or not this consistency group is the source for replication.
uuid
string
The unique identifier of the SnapMirror relationship.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency observed at the storage object, in microseconds. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
available_space
integer
iops_raw
iops_raw
latency_raw
latency_raw
size
integer
status
string
throughput_raw
throughput_raw
timestamp
string
The timestamp of the performance data.
used_space
integer
The total used space in the consistency group, in bytes.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
