REST API reference
Retrieve a license package
Retrieves details of a specific license package to understand its current configuration and status.
HTTP method and endpoint
GET /cluster/licensing/licenses/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific license package.
Note By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages.
  • system license show
  • system license show-status
name
string
path
True
Name of the license package.
state
string
query
False
Filter by state
licenses.start_time
string
query
False
Filter by licenses.start_time
licenses.installed_license
string
query
False
Filter by licenses.installed_license
  • Introduced in: 9.9
licenses.owner
string
query
False
Filter by licenses.owner
licenses.compliance.state
string
query
False
Filter by licenses.compliance.state
licenses.serial_number
string
query
False
Filter by licenses.serial_number
licenses.evaluation
boolean
query
False
Filter by licenses.evaluation
licenses.active
boolean
query
False
Filter by licenses.active
licenses.host_id
string
query
False
Filter by licenses.host_id
licenses.capacity.maximum_size
integer
query
False
Filter by licenses.capacity.maximum_size
licenses.capacity.used_size
integer
query
False
Filter by licenses.capacity.used_size
licenses.expiry_time
string
query
False
Filter by licenses.expiry_time
scope
string
query
False
Filter by scope
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
licenses
array[licenses]
Installed licenses of the package.
name
string
Name of the license.
scope
string
Scope of the license.
state
string
Summary state of package based on all installed licenses.
      "href": "/api/resourcelink"
  "licenses": [
      "capacity": {
        "maximum_size": 0,
        "used_size": 0
      "compliance": {
        "state": "compliant"
      "expiry_time": "2019-03-02T19:00:00Z",
      "host_id": "456-44-1234",
      "installed_license": "Core Bundle",
      "owner": "cluster1",
      "serial_number": "123456789",
      "start_time": "2019-02-02T19:00:00Z"
  "name": "NFS",
  "scope": "string",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
capacity
maximum_size
integer
Licensed capacity size (in bytes) that can be used.
used_size
integer
Capacity that is currently used (in bytes).
compliance
state
string
Compliance state of the license.
licenses
active
boolean
A flag indicating whether the license is currently being enforced.
capacity
capacity
compliance
compliance
evaluation
boolean
A flag indicating whether the license is in evaluation mode.
expiry_time
string
Date and time when the license expires.
host_id
string
A string that associates the license with a node or cluster.
installed_license
string
Name of license that enabled the feature.
owner
string
Cluster, node or license manager that owns the license.
serial_number
string
Serial number of the license.
start_time
string
Date and time when the license starts.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
