REST API reference
Retrieve a license package
Retrieves details of a specific license package, which is useful for managing and reviewing licensing information within your system.
HTTP method and endpoint
GET /cluster/licensing/licenses/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific license package.
Note By default, the GET method only returns licensed packages. You must provide the following query "state=unlicensed" to retrieve unlicensed packages.
  • system license show
  • system license show-status
name
string
path
True
Name of the license package.
entitlement.action
string
query
False
Filter by entitlement.action
  • Introduced in: 9.11
entitlement.risk
string
query
False
Filter by entitlement.risk
state
string
query
False
Filter by state
description
string
query
False
Filter by description
scope
string
query
False
Filter by scope
licenses.shutdown_imminent
boolean
query
False
Filter by licenses.shutdown_imminent
licenses.start_time
string
query
False
Filter by licenses.start_time
licenses.installed_license
string
query
False
Filter by licenses.installed_license
  • Introduced in: 9.9
licenses.capacity.maximum_size
integer
query
False
Filter by licenses.capacity.maximum_size
licenses.capacity.used_size
integer
query
False
Filter by licenses.capacity.used_size
licenses.owner
string
query
False
Filter by licenses.owner
licenses.host_id
string
query
False
Filter by licenses.host_id
licenses.serial_number
string
query
False
Filter by licenses.serial_number
licenses.expiry_time
string
query
False
Filter by licenses.expiry_time
licenses.compliance.state
string
query
False
Filter by licenses.compliance.state
licenses.evaluation
boolean
query
False
Filter by licenses.evaluation
licenses.active
boolean
query
False
Filter by licenses.active
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
description
string
License description
entitlement
entitlement
licenses
array[licenses]
Installed licenses of the package.
name
string
Name of the license.
scope
string
Scope of the license.
state
string
Summary state of package based on all installed licenses.
      "href": "/api/resourcelink"
  "description": "NFS License",
  "entitlement": {
    "action": "string",
    "risk": "string"
  "licenses": [
      "capacity": {
        "maximum_size": 0,
        "used_size": 0
      "compliance": {
        "state": "compliant"
      "expiry_time": "2019-03-02 14:00:00 -0500",
      "host_id": "456-44-1234",
      "installed_license": "Core Bundle",
      "owner": "cluster1",
      "serial_number": "123456789",
      "start_time": "2019-02-02 14:00:00 -0500"
  "name": "NFS",
  "scope": "string",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
entitlement
action
string
Entitlement action to be taken to mitigate the risk
risk
string
Entitlement risk of the package
capacity
maximum_size
integer
Licensed capacity size (in bytes) that can be used.
used_size
integer
Capacity that is currently used (in bytes).
compliance
state
string
Compliance state of the license.
licenses
active
boolean
A flag indicating whether the license is currently being enforced.
capacity
capacity
compliance
compliance
evaluation
boolean
A flag indicating whether the license is in evaluation mode.
expiry_time
string
Date and time when the license expires.
host_id
string
A string that associates the license with a node or cluster.
installed_license
string
Name of license that enabled the feature.
owner
string
Cluster, node or license manager that owns the license.
serial_number
string
Serial number of the license.
shutdown_imminent
boolean
A flag indicating whether the Cloud ONTAP system is going to shutdown as the Cloud platform license has already expired.
  • readOnly: 1
  • x-nullable: true
start_time
string
Date and time when the license starts.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
