REST API reference
Retrieve MetroCluster operations on the local cluster
Retrieves the list of MetroCluster operations on the local cluster to monitor and manage ongoing and completed operations.
HTTP method and endpoint
GET /cluster/metrocluster/operations
Introduced in
ONTAP 9.8
  • metrocluster operation history show
end_time
string
query
False
Filter by end_time
command_line
string
query
False
Filter by command_line
start_time
string
query
False
Filter by start_time
errors
string
query
False
Filter by errors
type
string
query
False
Filter by type
state
string
query
False
Filter by state
additional_info
string
query
False
Filter by additional_info
node.uuid
string
query
False
Filter by node.uuid
  • Introduced in: 9.9
node.name
string
query
False
Filter by node.name
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_operation]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "additional_info": "MetroCluster switchover with auto heal completed successfully.",
      "command_line": "metrocluster switchover",
      "end_time": "2016-03-10T14:35:16-08:00",
      "errors": [
        "siteB (warning): Unable to prepare the partner cluster for a pending switchback operation. Reason: entry doesn't exist. Reboot the nodes in the partner cluster before using the \"metrocluster switchback\" command."
      "node": {
        "name": "node1",
      "start_time": "2016-03-10T14:33:16-08:00",
      "state": "completed_with_warnings",
      "type": "switchover",
      "uuid": "11111111-2222-3333-4444-abcdefabcdef"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
node
Node from where the command is executed.
_links
_links
name
string
uuid
string
Data for a MetroCluster operation. REST: /api/cluster/metrocluster/operations
_links
self_link
additional_info
string
Additional information for the auto heal.
command_line
string
Command line executed with the options specified.
end_time
string
End Time
errors
array[string]
List of errors in the operation.
node
node
start_time
string
Start Time
state
string
Indicates the state of the operation.
type
string
Name of the operation.
uuid
string
Identifier for the operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
