Retrieve MetroCluster operations on the local cluster
GET /cluster/metrocluster/operations
Introduced In: 9.8
Retrieves the list of MetroCluster operations on the local cluster.
Related ONTAP Commands
metrocluster operation history show
Learn more
state |
string |
query |
False |
Filter by state |
errors |
string |
query |
False |
Filter by errors |
end_time |
string |
query |
False |
Filter by end_time |
type |
string |
query |
False |
Filter by type |
node.name |
string |
query |
False |
Filter by node.name
node.uuid |
string |
query |
False |
Filter by node.uuid
uuid |
string |
query |
False |
Filter by uuid |
additional_info |
string |
query |
False |
Filter by additional_info |
start_time |
string |
query |
False |
Filter by start_time |
command_line |
string |
query |
False |
Filter by command_line |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_operation] |
"next": {
"href": "/api/resourcelink"
"records": [
"additional_info": "MetroCluster switchover with auto heal completed successfully.",
"command_line": "metrocluster switchover",
"end_time": "2016-03-10T14:35:16-08:00",
"errors": [
"siteB (warning): Unable to prepare the partner cluster for a pending switchback operation. Reason: entry doesn't exist. Reboot the nodes in the partner cluster before using the \"metrocluster switchback\" command."
"node": {
"name": "node1",
"start_time": "2016-03-10T14:33:16-08:00",
"state": "completed_with_warnings",
"type": "switchover",
"uuid": "11111111-2222-3333-4444-abcdefabcdef"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
node
Node from where the command is executed.
_links |
name |
string |
uuid |
string |
Data for a MetroCluster operation. REST: /api/cluster/metrocluster/operations
_links |
additional_info |
string |
Additional information for the auto heal. |
command_line |
string |
Command line executed with the options specified. |
end_time |
string |
End Time |
errors |
array[string] |
List of errors in the operation. |
node |
Node from where the command is executed. |
start_time |
string |
Start Time |
state |
string |
Indicates the state of the operation. |
type |
string |
Name of the operation. |
uuid |
string |
Identifier for the operation. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
