REST API reference
Retrieve cluster peers
Accesses the collection of cluster peers to view their current configurations and status.
HTTP method and endpoint
GET /cluster/peers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of cluster peers.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cluster_peer]
    "next": {
      "href": "/api/resourcelink"
  "records": [
        "interfaces": {
      "authentication": {
        "expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
        "in_use": "string",
        "passphrase": "string",
        "state": "string"
      "encryption": {
        "proposed": "string",
        "state": "string"
      "initial_allowed_svms": [
          "name": "svm1",
      "ipspace": {
        "name": "exchange",
      "name": "cluster2",
      "peer_applications": [
        "snapmirror",
        "flexcache"
      "remote": {
        "ip_addresses": [
          "10.10.10.7"
        "name": "cluster2",
        "serial_number": "4048820-60-9"
      "status": {
        "state": "available",
        "update_time": "2017-01-25T11:20:13Z"
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "version": {
        "full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
        "generation": 9,
        "major": 4,
        "minor": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
interfaces
self
authentication
expiry_time
string
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour.
generate_passphrase
boolean
Auto generate a passphrase when true.
in_use
string
passphrase
string
A password to authenticate the cluster peer relationship.
state
string
encryption
proposed
string
state
string
self
_links
_links
name
string
The name of the SVM.
uuid
string
ipspace
The IPspace of the local intercluster LIFs.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
interfaces
ip_address
string
IPv4 or IPv6 address
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain
string
Broadcast domain that is in use within the IPspace.
gateway
string
The IPv4 or IPv6 address of the default router.
interfaces
array[interfaces]
netmask
string
IPv4 mask or netmask length.
remote
ip_addresses
array[string]
The IPv4 addresses, IPv6 addresses, or hostnames of the peers.
name
string
The name of the remote cluster.
serial_number
string
The serial number of the remote cluster.
status
state
string
update_time
string
The last time the state was updated.
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full
string
The full cluster version string.
generation
integer
The generation portion of the version.
major
integer
The major portion of the version.
minor
integer
The minor portion of the version.
cluster_peer
_links
_links
authentication
authentication
encryption
encryption
array[initial_allowed_svms]
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship.
ipspace
ipspace
name
string
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster.
peer_applications
array[string]
Peering applications against which allowed SVMs are configured.
remote
remote
status
status
uuid
string
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship.
version
version
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
