Retrieve cluster peers
Retrieves the collection of cluster peers to view and manage the relationships between clusters. This is useful for monitoring connectivity and replication configurations.
HTTP method and endpoint
GET /cluster/peers
Introduced in
ONTAP 9.6
name |
string |
query |
False |
Filter by name
status.state |
string |
query |
False |
Filter by status.state
status.update_time |
string |
query |
False |
Filter by status.update_time
version.full |
string |
query |
False |
Filter by version.full
version.minor |
integer |
query |
False |
Filter by version.minor
version.generation |
integer |
query |
False |
Filter by version.generation
version.major |
integer |
query |
False |
Filter by version.major
ip_address |
string |
query |
False |
Filter by ip_address
remote.serial_number |
string |
query |
False |
Filter by remote.serial_number
remote.ip_addresses |
string |
query |
False |
Filter by remote.ip_addresses
remote.name |
string |
query |
False |
Filter by remote.name
initial_allowed_svms.uuid |
string |
query |
False |
Filter by initial_allowed_svms.uuid
initial_allowed_svms.name |
string |
query |
False |
Filter by initial_allowed_svms.name
authentication.passphrase |
string |
query |
False |
Filter by authentication.passphrase
authentication.in_use |
string |
query |
False |
Filter by authentication.in_use
authentication.state |
string |
query |
False |
Filter by authentication.state
authentication.expiry_time |
string |
query |
False |
Filter by authentication.expiry_time
uuid |
string |
query |
False |
Filter by uuid
encryption.proposed |
string |
query |
False |
Filter by encryption.proposed
encryption.state |
string |
query |
False |
Filter by encryption.state
ipspace.name |
string |
query |
False |
Filter by ipspace.name
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid
peer_applications |
string |
query |
False |
Filter by peer_applications
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[cluster_peer] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"interfaces": {
"authentication": {
"expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
"generate_passphrase": true,
"in_use": "string",
"passphrase": "string",
"state": "string"
"encryption": {
"proposed": "string",
"state": "string"
"initial_allowed_svms": [
"name": "svm1",
"ip_address": "10.10.10.7",
"ipspace": {
"name": "Default",
"name": "cluster2",
"peer_applications": [
"snapmirror",
"flexcache"
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"serial_number": "4048820-60-9"
"status": {
"state": "available",
"update_time": "2017-01-25 11:20:13 +0000"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
interfaces |
self |
authentication
expiry_time |
string |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour. |
in_use |
string |
passphrase |
string |
A password to authenticate the cluster peer relationship. |
state |
string |
encryption
proposed |
string |
state |
string |
_links
self |
_links |
name |
string |
uuid |
string |
ipspace
The IPspace of the local intercluster LIFs.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
interfaces
ip_address |
string |
IPv4 or IPv6 address |
local_network
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node.
broadcast_domain |
string |
Broadcast domain that is in use within the IPspace. |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
interfaces |
array[interfaces] |
netmask |
string |
IPv4 mask or netmask length. |
remote
ip_addresses |
array[string] |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers. |
name |
string |
The name of the remote cluster. |
serial_number |
string |
The serial number of the remote cluster. |
status
state |
string |
update_time |
string |
The last time the state was updated. |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
cluster_peer
_links |
authentication |
encryption |
initial_allowed_svms |
array[initial_allowed_svms] |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. |
ip_address |
string |
ipspace |
The IPspace of the local intercluster LIFs. |
name |
string |
Optional name for the cluster peer relationship. By default, it is the name of the remote cluster, or a temporary name might be autogenerated for anonymous cluster peer offers. |
peer_applications |
array[string] |
Peering applications against which allowed SVMs are configured. |
remote |
status |
uuid |
string |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship. |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
