Retrieve schedules
Retrieves a schedule to view its configuration and details. This can help you manage and coordinate tasks effectively within your system.
HTTP method and endpoint
GET /cluster/schedules
Introduced in
ONTAP 9.6
svm.uuid |
string |
query |
False |
Filter by svm.uuid
svm.name |
string |
query |
False |
Filter by svm.name
name |
string |
query |
False |
Filter by name |
cluster.uuid |
string |
query |
False |
Filter by cluster.uuid |
cluster.name |
string |
query |
False |
Filter by cluster.name |
type |
string |
query |
False |
Filter by type |
interval |
string |
query |
False |
Filter by interval |
scope |
string |
query |
False |
Filter by scope
cron.minutes |
integer |
query |
False |
Filter by cron.minutes |
cron.weekdays |
integer |
query |
False |
Filter by cron.weekdays |
cron.hours |
integer |
query |
False |
Filter by cron.hours |
cron.days |
integer |
query |
False |
Filter by cron.days |
cron.months |
integer |
query |
False |
Filter by cron.months |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[schedule] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cluster": {
"name": "cluster1",
"cron": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"interval": "P1DT2H3M4S",
"name": "string",
"scope": "string",
"svm": {
"name": "svm1",
"type": "string",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
459760 |
The schedule specified is not a valid schedule. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
cluster
The cluster that owns the schedule. Defaults to the local cluster.
name |
string |
Cluster name |
uuid |
string |
Cluster UUID |
cron
Details for schedules of type cron.
days |
array[integer] |
The days of the month the schedule runs. Leave empty for all. |
hours |
array[integer] |
The hours of the day the schedule runs. Leave empty for all. |
minutes |
array[integer] |
The minutes the schedule runs. Required on POST for a cron schedule. |
months |
array[integer] |
The months of the year the schedule runs. Leave empty for all. |
weekdays |
array[integer] |
The weekdays the schedule runs. Leave empty for all. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
schedule
Complete schedule information
_links |
cluster |
The cluster that owns the schedule. Defaults to the local cluster. |
cron |
Details for schedules of type cron. |
interval |
string |
An ISO-8601 duration formatted string. |
name |
string |
Schedule name. Required in the URL or POST body. |
scope |
string |
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster. |
svm |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
