REST API reference
Retrieve schedules
Retrieves a schedule to manage and automate recurring tasks within your ONTAP environment. This helps in maintaining efficient operations by ensuring tasks are executed at specified intervals.
HTTP method and endpoint
GET /cluster/schedules
Introduced in
ONTAP 9.6
svm.uuid
string
query
False
Filter by svm.uuid
  • Introduced in: 9.10
svm.name
string
query
False
Filter by svm.name
cluster.uuid
string
query
False
Filter by cluster.uuid
cluster.name
string
query
False
Filter by cluster.name
type
string
query
False
Filter by type
scope
string
query
False
Filter by scope
interval
string
query
False
Filter by interval
cron.minutes
integer
query
False
Filter by cron.minutes
  • Max value: 59
  • Min value: 0
cron.days
integer
query
False
Filter by cron.days
  • Max value: 31
  • Min value: 1
cron.weekdays
integer
query
False
Filter by cron.weekdays
  • Max value: 6
  • Min value: 0
cron.hours
integer
query
False
Filter by cron.hours
  • Max value: 23
  • Min value: 0
cron.months
integer
query
False
Filter by cron.months
  • Max value: 12
  • Min value: 1
name
string
query
False
Filter by name
  • maxLength: 256
  • minLength: 1
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[schedule]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "cron": {
        "days": [
          "integer"
        "hours": [
          "integer"
        "minutes": [
          "integer"
        "months": [
          "integer"
        "weekdays": [
          "integer"
      "interval": "P1DT2H3M4S",
      "name": "string",
      "scope": "string",
      "svm": {
        "name": "svm1",
      "type": "string",
Status: Default
ONTAP Error Response Codes
Error Code Description
459760
The schedule specified is not a valid schedule.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
cluster
The cluster that owns the schedule. Defaults to the local cluster.
name
string
Cluster name
uuid
string
Cluster UUID
cron
Details for schedules of type cron.
days
array[integer]
The days of the month the schedule runs. Leave empty for all.
hours
array[integer]
The hours of the day the schedule runs. Leave empty for all.
minutes
array[integer]
The minutes the schedule runs. Required on POST for a cron schedule.
months
array[integer]
The months of the year the schedule runs. Leave empty for all.
weekdays
array[integer]
The weekdays the schedule runs. Leave empty for all.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
schedule
Complete schedule information
_links
_links
cluster
cluster
cron
cron
interval
string
An ISO-8601 duration formatted string.
name
string
Schedule name. Required in the URL or POST body.
scope
string
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
svm
svm
type
string
Schedule type
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
