Retrieves the software packages for a cluster
learn more
doc /cluster/software](#docs-cluster-cluster_software)
GET /cluster/software/packages
Introduced In: 9.6
Retrieves the software packages for a cluster.
Related ONTAP commands
cluster image package show-repository
Learn more
version |
string |
query |
False |
Filter by version
create_time |
string |
query |
False |
Filter by create_time
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[software_package] |
"next": {
"href": "/api/resourcelink"
"records": [
"create_time": "2019-02-04T19:00:00Z",
"version": "ONTAP_X"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
software_package
_links |
create_time |
string |
Indicates when this package was loaded |
version |
string |
Version of this package
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
