Retrieve cluster software packages
Accesses the list of software packages available for a cluster, which is essential for managing and updating cluster software components.
HTTP method and endpoint
GET /cluster/software/packages
Introduced in
ONTAP 9.6
Usage notes
Retrieves the software packages for a cluster.
Related ONTAP commands
cluster image package show-repository
Learn more
version |
string |
query |
False |
Filter by version
create_time |
string |
query |
False |
Filter by create_time
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[software_package] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"create_time": "2019-02-04 14:00:00 -0500",
"version": "ONTAP_X"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
software_package
_links |
create_time |
string |
Indicates when this package was loaded |
version |
string |
Version of this package
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
