Retrieve an Ethernet switch port
GET /network/ethernet/switch/ports/{switch}/{identity.name}/{identity.index}
Introduced In: 9.8
Retrieves an ethernet switch port.
Related ONTAP commands
system switch ethernet interface show
switch |
string |
path |
True |
Switch Name |
identity.name |
string |
path |
True |
Interface Name |
identity.index |
integer |
path |
True |
Interface Index |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
configured |
string |
Administrative Status. |
duplex_type |
string |
Duplex Settings. |
identity |
isl |
boolean |
Is configured as an ISL link. |
mac_address |
string |
MAC Address. |
mtu |
integer |
MTU. |
remote_port |
Remote port |
speed |
integer |
Interface Speed(Mbps) |
state |
string |
Operational Status. |
statistics |
These are raw counters for the device associated with the Ethernet port. |
switch |
The name of the specified cluster or storage switch. |
type |
string |
Interface Type. |
vlan_id |
array[integer] |
"href": "/api/resourcelink"
"configured": "string",
"duplex_type": "string",
"identity": {
"index": 0,
"name": "string",
"number": 0
"mac_address": "string",
"mtu": 0,
"remote_port": {
"device": {
"node": {
"name": "node1",
"shelf": {
"uid": "7777841915827391056"
"mtu": 0,
"name": "string"
"speed": 0,
"state": "string",
"statistics": {
"receive_raw": {
"discards": 100,
"errors": 200,
"packets": 500
"transmit_raw": {
"discards": 100,
"errors": 200,
"packets": 500
"switch": {
"name": "RTP-SS01-510R03(FOC223443KQ)"
"type": "string",
"vlan_id": [
"integer"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
identity
index |
integer |
Interface Index. |
name |
string |
Interface Name. |
number |
integer |
Interface Number. |
_links
self |
node
_links |
name |
string |
uuid |
string |
shelf
Shelf connected to this port.
_links |
uid |
string |
device
Device connected to port.
node |
shelf |
Shelf connected to this port. |
remote_port
Remote port
device |
Device connected to port. |
mtu |
integer |
MTU in octets |
name |
string |
Port Name. |
receive_raw
Packet receive counters for the Ethernet port.
discards |
integer |
Total number of discarded packets. |
errors |
integer |
Number of packet errors. |
packets |
integer |
Total packet count. |
transmit_raw
Packet transmit counters for the Ethernet port.
discards |
integer |
errors |
integer |
packets |
integer |
statistics
receive_raw |
Packet receive counters for the Ethernet port. |
transmit_raw |
Packet transmit counters for the Ethernet port. |
switch
_links |
name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
