REST API reference
Retrieve an Ethernet switch port
Retrieves information about an Ethernet switch port, which is useful for monitoring and managing your network configuration.
HTTP method and endpoint
GET /network/ethernet/switch/ports/{switch}/{identity.name}/{identity.index}
Introduced in
ONTAP 9.8
Usage notes
Retrieves an ethernet switch port.
  • system switch ethernet interface show
switch
string
path
True
Switch Name
identity.name
string
path
True
Interface Name
identity.index
integer
path
True
Interface Index
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
configured
string
Administrative Status.
duplex_type
string
Duplex Settings.
identity
identity
isl
boolean
Is configured as an ISL link.
mac_address
string
MAC Address.
mtu
integer
MTU.
remote_port
remote_port
Remote port.
roles
array[roles]
speed
integer
Interface Speed(Mbps).
state
string
Operational Status.
statistics
statistics
These are raw counters for the device associated with the Ethernet port.
switch
switch
The name of the specified cluster or storage switch.
type
string
Interface Type.
vlan_id
array[integer]
vpc_peer_link
boolean
Is configured as a Virtual Port Channel (vPC) peer-link.
      "href": "/api/resourcelink"
  "configured": "string",
  "duplex_type": "string",
  "identity": {
    "breakout": {
      "number": 1,
      "physical_port": "Ethernet1/9"
    "index": 0,
    "name": "string",
    "number": 0,
    "slot": 0
  "mac_address": "string",
  "mtu": 0,
  "remote_port": {
    "device": {
      "dcn": {
        "name": "node1",
        "serial_number": "4048820-60-9",
      "discovered_name": "stiA400-311",
      "node": {
        "name": "node1",
      "shelf": {
        "module": "string",
        "name": "1.1",
        "uid": "12439000444923584512"
    "functional_roles": [
      "string"
    "mtu": 0,
    "name": "string"
  "roles": [
      "dr_group": "string",
      "type": "string"
  "speed": 0,
  "state": "string",
  "statistics": {
    "receive_raw": {
      "discards": 100,
      "errors": 200,
      "packets": 500
    "timestamp": "2024-11-18 15:52:17 +0000",
    "transmit_raw": {
      "discards": 100,
      "errors": 200,
      "packets": 500
  "switch": {
    "name": "RTP-SS01-510R03(FOC223443KQ)"
  "type": "string",
  "vlan_id": [
    "integer"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
breakout
number
integer
Breakout port sub-interface number.
physical_port
string
Breakout physical port name.
identity
breakout
breakout
index
integer
Interface Index.
name
string
Interface Name.
number
integer
Interface Number.
slot
integer
Interface slot.
self
dcn
Compute node connected to this port.
_links
_links
name
string
Compute node name.
serial_number
string
Compute node serial number.
uuid
string
Compute node UUID.
node
_links
_links
name
string
uuid
string
shelf
Shelf connected to this port.
_links
_links
module
string
Shelf module connected to this port.
name
string
uid
string
device
Device connected to port.
dcn
dcn
discovered_name
string
Raw name of the discovered device.
node
node
shelf
shelf
remote_port
Remote port.
device
device
functional_roles
array[string]
mtu
integer
MTU in octets.
name
string
Remote port name.
roles
Allowed use for this port.
dr_group
string
DR group.
type
string
Allowed use type.
zone
integer
Zone ID to differentiate between roles with the same type.
receive_raw
Packet receive counters for the Ethernet port.
discards
integer
Total number of discarded packets.
errors
integer
Number of packet errors.
packets
integer
Total packet count.
transmit_raw
Packet transmit counters for the Ethernet port.
discards
integer
errors
integer
packets
integer
Total packet count.
statistics
receive_raw
receive_raw
timestamp
string
The time the statistics were gathered.
transmit_raw
transmit_raw
switch
_links
self_link
name
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
