Retrieve the lock for a specific UUID
Accesses the lock details for a specific UUID to examine current lock status and related information.
HTTP method and endpoint
GET /protocols/locks/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the lock for a specific UUID.
Related ONTAP commands
vserver locks show
uuid |
string |
path |
True |
Lock ID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
byte_lock |
client_address |
string |
IP address of the client holding the lock. |
constituent |
boolean |
Indicate if volume is contituent or not. |
delegation |
string |
Type of delegation. |
interface |
node |
oplock_level |
string |
The oplock level determines which operations the client may cache locally. |
owner_id |
string |
Owner ID. |
path |
string |
Object path |
protocol |
string |
Type of lock protocol. |
share_lock |
smb |
state |
string |
State of lock. |
svm |
type |
string |
Type of lock. |
uuid |
string |
Lock UUID |
volume |
"byte_lock": {
"length": 10,
"offset": 100
"client_address": "0.0.0.0",
"delegation": "string",
"interface": {
"href": "/api/resourcelink"
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"node": {
"name": "node1",
"oplock_level": "string",
"owner_id": "string",
"path": "string",
"protocol": "string",
"share_lock": {
"mode": "string"
"smb": {
"connect_state": "string",
"open_group_id": "string",
"open_type": "string"
"state": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "ceeac1b4-8646-4c76-a054-1c96e87594aa",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
byte_lock
exclusive |
boolean |
Indicates whether it is an exclusive bytelock. |
length |
integer |
Length of the bytelock starting from the offset. |
mandatory |
boolean |
Indicates whether or not the bytelock is mandatory. |
offset |
integer |
Starting offset for a bytelock. |
soft |
boolean |
Indicates whether it is a soft bytelock. |
super |
boolean |
Indicates whether it is a super bytelock. |
href |
string |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
_links |
name |
string |
uuid |
string |
mode |
string |
Types of share lock modes. |
soft |
boolean |
Indicates whether it is a soft share lock. |
smb
connect_state |
string |
SMB connection state. |
open_group_id |
string |
SMB open group ID. |
open_type |
string |
SMB open type. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
