REST API reference
Retrieve the lock for a specific UUID
Accesses the lock details for a specific UUID to examine current lock status and related information.
HTTP method and endpoint
GET /protocols/locks/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves the lock for a specific UUID.
  • vserver locks show
uuid
string
path
True
Lock ID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
byte_lock
byte_lock
client_address
string
IP address of the client holding the lock.
constituent
boolean
Indicate if volume is constituent or not.
delegation
string
Type of delegation.
interface
interface
A network interface. Either UUID or name may be supplied on input.
node
node
oplock_level
string
The oplock level determines which operations the client may cache locally.
owner_id
string
Owner ID.
path
string
Object path
protocol
string
Type of lock protocol.
share_lock
share_lock
smb
smb
state
string
State of lock.
svm
svm
type
string
Type of lock.
uuid
string
Lock UUID
volume
volume
  "byte_lock": {
    "length": "10",
    "offset": "100"
  "client_address": "0.0.0.0",
  "delegation": "string",
  "interface": {
        "href": "/api/resourcelink"
    "ip": {
      "address": "10.10.10.7"
    "name": "lif1",
  "node": {
    "name": "node1",
  "oplock_level": "string",
  "owner_id": "string",
  "path": "string",
  "protocol": "string",
  "share_lock": {
    "mode": "string"
  "smb": {
    "connect_state": "string",
    "open_group_id": "string",
    "open_type": "string"
  "state": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "ceeac1b4-8646-4c76-a054-1c96e87594aa",
  "volume": {
    "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
byte_lock
exclusive
boolean
Indicates whether it is an exclusive bytelock.
length
integer
Length of the bytelock starting from the offset.
mandatory
boolean
Indicates whether or not the bytelock is mandatory.
offset
integer
Starting offset for a bytelock.
soft
boolean
Indicates whether it is a soft bytelock.
super
boolean
Indicates whether it is a super bytelock.
string
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
_links
_links
name
string
uuid
string
share_lock
mode
string
Types of share lock modes.
soft
boolean
Indicates whether it is a soft share lock.
smb
connect_state
string
SMB connection state.
open_group_id
string
SMB open group ID.
open_type
string
SMB open type.
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
